Question about Humminbird NS25 GPS Receiver
Antenna not working
Can you use a more upto date antenna as the ns25 is discontinued
In the start up mode as not connected can any body help
What happened since then. Have you solved it somehow? I have the same problem..
Apr 02, 2012 | Humminbird NS25 GPS Receiver
Gps ns25
Please check the mount and the wiring throughly as its a loose contact issue nothing else.
Aug 07, 2008 | Humminbird NS25 GPS Receiver
Moisture in antena
Hello there.
Please click here to find a replacement antennae for your Humminbird device.
Hope this helps.
Jun 05, 2008 | Humminbird NS25 GPS Receiver
Bios are not upto date
Thank you for that information!!!!!!!!!!!!!!
so what is the question???????????
May 16, 2010 | IBM NetVista PC Desktop
Antenna AN-LPN1 for my Sony ICF-SW7600
Yes, its discontinued item.
You can try it in ebay or some thing.
Apr 17, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
Dtv and more channels
The original date for digital conversion for television broadcasts was February 17, 2009. The date has been extended to June 12, 2009 by Congress, at which time all analog television broadcasting will be discontinued. Some stations, due to technical reasons, have already made the transition, while others continue to broadcast an analog signal. This may attribute to your only receiving 4 stations via your "rabbit ear" antenna.
You can check the website of your favorite stations to see when they will make the transition to digital broadcasting. Also, households are eligible for up to two coupons for $40 each toward the purchase of certain converter boxes. You can check out the details at https://www.dtv2009.gov/ for more information regarding the coupons.
Feb 18, 2009 | Insignia Digital-to-Analog Converter for...
Maps
NO. YOUR SOLUTION NOT SATISFACTORY. NO HELP AT ALL
Sep 14, 2008 | GPS
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Gps ns25
The wiring within the Screen unit seems to be very poorly done, there are 4 cables to the GPS side of things and these can contact each other as there is a portion of the wire where it enters the connector that is bare, and if these touch one another then you will get nothing.
Dismantle the head unit and check the cables, i would be inclined to shrink wrap the bare portion of each cable.
Hope that this helps, it might not be the answer, but it is worth checking.
adrian.
Humminbird NS25 GPS Receiver Logo
47 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
