Indesit WG1286 the machine keeps filling after use,although it is very slow it takes around 10 days to get up to the door just wondering what part i might need and how much will it cost
    Problem Solver:
  • 11 Answers
The problem is with the water valve / solenoid. It is most likely dirty. You can try to clean it yourself or replace it. It should be about $50. A more simple solution is just to shut the valves between use. This is actually a good idea even if your machine is not filling up with water as it saves you from a flood is the flexible hoses were to puncture. Regards, Denis
Posted on Oct 09, 2007
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares > Home > Washers & Dryers > Washing Machines
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
My icemaker in my large French door Samsung refrigerator takes forever to make more ice. Is there some way to increase ice production? It takes 2 to 3 days to fill up the ice bucket. There is nothing in...
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Sep 08, 2009 | Samsung RF265AA Bottom Freezer French Door...
Indesit WG1234T washer drum not turning
hi the sound of things,the brushes on the motor are worn out.easy to replace,each brush is secured by two screws at the rear of the motor,and will be black in colour,or a reddish may be easier to remove the motor to gain a cheap set from ebay,as generally speaking a repair and spares shop will ask four times the going rate.anyhow,once removed there should be at least 7mm of carbon left to make contact with the commutator(the part of the motor that turns)
hope this helps, belt could have snapped or come off also....
Apr 13, 2009 | Indesit W 123 Front Load Washer
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit D41 dishwasher problem
If things trip as soon as you turn the machine on, rather than waiting until partway through the cycle, then I guess you probably don't have the usual earth fault, which is a degraded heater element. The fact that things only trip with the door shut isn't all that bizarre - there's an interlock to shut the machine off when you open the door (stops interfering toddlers getting a scalding shower) - sounds like your earth fault is downstream of this. Once you've eliminated the element, and with a history of a house move, then there's every liklihood that whatever's causing your problem is going to be visible to the naked eye. With the power and water off, have a good look around inside the back and underneath. I reckon there are three things you should be checking for: 1. Wires that have become dislodged during the move or had metalwork bent into them (concentrate on the underside of the machine, where a mover's trolley might have got in and done some harm 2. Major lumps of machinery having become dislodged by the dishwasher getting dropped. 3. Moisure (especially salt water from the ion exchange bed) which has got swilled around in places it shouldn't have by movers tipping the machine on its side. For 1 and 2, fix what you see, then see what happens. For 3, wash out any salt contamination, let all freshwater dry out thoroughly (so leave it for three times as long as you think it's going to take) then plug it in and see what happens. A.
Jun 24, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
