Question about Logitech Televison & Video
Can harmony one remote contol VIZIO S4251w-B4 5.1 Soundbar with Wireless Subwoofer and Satellite Speakers
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
Why are my satellite speakers not working?
set sound to defoult on main receiver power of and then power on
Sep 02, 2014 | Vizio S4251w-B4 5.1 Soundbar System 5.1...
Having trouble getting the subwoofer and satellite speakers to work with the soundbar.
hello anonymus if your system is working and the soundbar does not
make sure you have the right connector to inject signal to soundbar some of them like you have has a tiny hole to reset it and dont forget to use the remote control i hope it works
Aug 25, 2014 | Vizio S4251w-B4 5.1 Soundbar System 5.1...
Vizio help
Not sure the issue. HDMI from cable box to TV. Same with Vizio.
The soundbar usually connects to the optical out from the TV to the in on the soundbar. Subwoofer has to be paired to the soundbar. Instructions should explain or maybe find online by manufacturer
Aug 15, 2014 | Televison & Video
My Vizio VSB210WS Soundbar is not paring with the wireless subwoofer
bluetooth speakers pair and connect to a 'source' not other speakers.
Mar 19, 2014 | Vizio VSB210WS Soundbar
VIZIO VHT510. soundbar and subwoofer work. No sound from satellite speakers
Do you have them connected to the sub? Those satellite speakers pick up the fainter sounds and work best in movies with 5.1 surround sound. Make sure they are behind the primary listening position. And try them with a 5.1 surround movie. If all speakers are up front switch to front listen mode. Good luck.
Mar 06, 2011 | Vizio VHT510 Theater System
I recently bought a Logitech Harmony One universal remote for my VIzio HDTV and Vizio soundbar. Following the setup instructions on the DVD I sucessfully set up the remote to control the TV, cable box...
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
Jan 09, 2011 | Logitech Harmony One Advanced Universal...
Televison & Video Logo
254 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
