Question about Panasonic DMR-E80H DVD Recorder
Is there a solution?
I have just brought a Panasonic LCD TV (TX-26LMD70) and DVD recorder (DMR-EX77EB) with hard drive. They have been set up according to the instructions in the manual and everything is working fine except that I cannot record onto the hard drive if the TV is on standby. I found this out while I was away over the weekend and when I got back all the programmed recordings were black, whereas if I leave it to record while the TV was on it works fine. Is there a solution to this or am I always going to have to leave the TV on when I want to record something when I'm at work for example?
You need to set your programs up to "record" via the cable menu screen ( select program, pick to record program ).
Doing it this way, the cable box will turn on at the time you had it set to record. The TV will not turn on.
This worked for me.
Posted on Feb 20, 2008
I have a similar setup. Your problem is because you are selecting the recording on the digital tuner of the TV. When you do this you need to keep the TV on and canot switch channel.
You should make sure you use the digital tuner on the DMR-EX77 recorder and then you can use the TV as you like.
Posted on Jan 07, 2008
SOURCE:
White colour displaying as pink on DVD recorder DMR-EX77EB, problem just started a few weeks ago.
Very similar problem with my DMR-EZ27. About 10 minutes into playing back a DVD the color starts going away until I only see a black/white movie. Sometimes color comes back in partially then back to b/w
Feb 13, 2011 | Panasonic DMR-EZ48VK DVD Recorder
DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Nov 08, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Jan 30, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic DVD Recorder DMR-EX77EB says no signal but no problem with aerial TV says signal strength 5 no problem for over a year since bought new until now
I restarted 'Auto setup' this deletes the channel settings (which had presumably been corrupted) and re-installed them from the incoming signal.
alexanderosb
Aug 30, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Hdmi connection
you need to connect to your tv via scart untill you have been into the setup and enabled hdmi
Dec 29, 2007 | Panasonic DMR-E80H DVD Recorder
Dmr-ex77eb-k
The Panasonics are very picky about the media ie brand and quality of the DVD blank. Try a different brand and see if that helps.
Nov 23, 2007 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-E80H DVD Recorder Logo
258 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
