E3 daewoo E3 error on daewoo washer dryer, when dryer is switched
2 Suggested Answers
  • 9 Answers
SOURCE: error code e3
its a long drain which means you have 8 minutes to drain and its taking to long you need to remove the bottom panel 2 to 3 screws and clean out you drain they will have water in there so be ready for about a gallon or two to drain out and also check to see if your drain hose isn't kinked
Posted on Mar 12, 2013
What is Error HI?
you didn't mention the model, but on the washer/dryer combo units, the H1 means the following:
Dryer temperature sensor error detected A fault has been detected with the dryer temperature sensor on washer dryer models.
  • Check connections to dryer sensor
  • Check temperature sensor
May 15, 2016 | Daewoo Washing Machines
What is meant by L E?
Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 02, 2015 | Daewoo Washing Machines
I have E3 error cod on a washing machine it is a Bosch
What Model
The error code E3 means that the door isn't registering as closed, even if physically it is.
This is usually due to a faulty door interlock switch..
Check it physically to see if it has any heat damage or has come partially unplugged.
Here is how to change the door switch:
Door Lock Latch Replacement part 131763202 Frigidaire Affinity Washer...
Apr 07, 2015 | Bosch Washing Machines
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
·Close the door!
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
Error code E3
E3 on Samsung Washers is generally associated with Overflow/Fill problem, and is often the result of using the WRONG type of detergent or overdosing with detergent, both leading to excessive foam. This soap foam falsifies the pressure switch detection error of an overfill.
Jun 26, 2014 | Samsung Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
