Question about Panasonic Single Split Wall Mounted Air Conditioner
Air conditioner part no longer made
Board in head unit no longer available can I replace the head unit and keep the outdoor unit as it still works
2 Suggested Answers
  • 34 Answers
SOURCE: panasonic air conditioner issues
does it freeze up? this could be a sign of low freon. does the fan turn on? if not the compressor will get hot and shut itself down on overload the fan can be easily replaced for around 100.00
Posted on Oct 10, 2009
After I replaced the pcb on my samsung air conditioner indoor unit it won't start and all 3 led's are blinking
I have had similar problems with Samsung. Apparently, the indoor board fits a lot of different models and each has to be "programmed" in to suit your model. Not sure what was wrong with your machine before but it has been known for these units to have a faulty outdoor fan motor which causes the outdoor board to fail as well. When this happens, the indoor unit will usually work fine for about a minute or 2 and then shut down, with lights flashing. The outdoor wont start at all. If these were the symptoms, I would suggest putting your old indoor PCB back and then getting a new outdoor fan motor and outdoor PCB.
Apr 19, 2015 | Samsung Heating & Cooling
Leto senl/18hd/I or 18hd/o unit keeps turning itself on and switching from heat to a/c mode on it's own.
Is unit still under warranty? If so call manufacturer And request new board and is there a board for outdoor unit? If so, get one of those too. Tell them U will return unused parts. replace outdoor board first and check. replace indoor board and test.
Oct 24, 2014 | Senville 18000 BTU Ductless Air...
Fujitsu ASY12RSE-W. Unit not working at all. Timer lamp blinking & operation lamp flashing twice
It's showing an error code for the outdoor unit no communication from the outdoor circuit board.
Jul 30, 2013 | Fujitsu 24C1 Air Conditioner
Trane xr90 furnace keeps on running
Well my friend, the thermostat board of land in the interior michanimatos.echei two thermistors, what the problem is the bronze thermistor.take it from there which is anchored in the thick pipe that leaves the air conditioner and is connected to the outdoor unit. check this option if it works and if it works changed the thermistor.
Apr 07, 2012 | DeLonghi Trane 5t Rooftop Air Conditioner...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
We have a P8? CAN'T FIND MANAUL
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have an old ruud achiever 10 i shut it off by the thermastat to change filters and now my outside unit will not come on at all, we replaced the fan motor and we checked the power , power is going all the...
High, sounds like the time delay relay went out when you shut it off at the stat, and has failed. It is a small 24 volt circuit board or small black timer box that is adjustable and if it fails will keep the outdoor unit from ever coming on. If you know what terminals to jump across, it can be bypass completely. If it fails which happens many times as I carry many different types for the people who want a new one, it keeps the outdoor unit from starting at all. When it is working, it prevents the unit from short cycling.
Shastalaker7
Aug 14, 2010 | Ruud UAMB Air Conditioner
I have a fujitsu twin head air con that is at least 10 years old the external compressor is not turning on but it does work my fridge mech was not sure of problem but thought it was the control board not...
The outdoor PCB has a series of led's on it which indicate the status of what is operating. If the lights are on and nothings working then you will need a new outdoor pcb which is only availible from fujitsu.
Jan 09, 2010 | Fujitsu 18C1 Air Conditioner
AS12S4GB AIR CONDITIONER 4 BEEPING
when you restart the unit monitor the outdoor unit and see if the compressor and outdoor fan starts up . before the beeps . you can try reseting everything by disconecting all power to outdoor unit .
hope this helps please leave fead back / keep me informed
Oct 20, 2008 | Samsung AS18A6RB Air Conditioner
Panasonic Single Split Wall Mounted Air Conditioner Logo
14 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
