Question about Electronics - Others
How Can I get usb memory stick to play through my hills hd94003 set top box
2 Suggested Answers
ITTech7574
  • 85 Answers
SOURCE: I left my memory stick in my lap top. Dislodged
i guess you just broke the usb.. try to connect on other pcs if still works...hope this helps..
Posted on Sep 01, 2009
Hills set top box usb file support
Do you need,set top box with usb support or you have set top box,that is not supporting usb or stopped supporting usb.
Click the link below :---- http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
--------Thanks.
Jan 27, 2012 | Audio Players & Recorders
I have a vaio sony 4 GB flash disk when i try to put pics and song and videos in it it works for some min and in the same computer but when i try to put it to another pc after playing the video it says can...
Hello
theres a few things you can do, when you do format your memory stick make sure you format it to the default settings.
Also make sure everytime you put files onto your memory stick that you remove the memory stick safely you can do this by right clicking the memory stick and pressing eject.
However the problem could be that your memory stick is corrupt.
Jul 13, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
How to download a psp games for free??????????
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 19, 2011 | Sony PlayStation Portable (PSP) Console
How to download from the computer to psp?
3. EXIT USB MODE
Apr 12, 2011 | Sony PlayStation Portable (PSP) Console
What is the usb port for
hi, you can store music on a usb memory stick from your computer then plug the memory stick into your stereo then you can play your music thats on the memory on your stereo.
it just means you can copy music from your pc and play it on your stereo via a usb stick so you could copy an album onto a memory stick then plug it into your stereo then you can listen to the album in your car, you can also store dvds onto a usb stick and play them in your car its just a way of getting more info onto your dvd player giving you the chance to play things you have on your pc.
how ever some times you may have problems with certain formats and anything copied means you lose you warranty due to the fact your not using originals.
so you use these at your own risks
Apr 19, 2010 | Pyle PLD5MU Car DVD Player
I have a memory stick with files on and for some reason its asking me to re format it, but i dont want to lose the files.
If you reformat you will definitely lose the files. Here is a protocol that may get you up and running again. If it does not, check at a local staples or other computer dealer and see if they can retreve your data as you memory stick may be a goner.
Remove the memory stick from the USB port on your computer and then reconnect it to make sure it was installed properly.
  • Step 2 Check the sides of the memory stick and see if it has a "Write Protection" tab. Slide the tab over to the "Unlocked" position if it was set to "Locked" and attempt to use the memory stick again.
  • Step 3 Remove any USB hubs or extra USB devices that are connected to the other ports on the computer in case you have accidentally gone over the maximum number of devices that the motherboard can handle.
  • Step 4 Click on the Windows "Start" icon located at the bottom-left side of the main desktop toolbar. Click on "My Computer" and wait for a new window to pop up. Check to see if there is a new drive in the list of options that corresponds to the USB memory stick.
  • Step 5 Click on the "Map a Network Drive" button located at the top of the window if the USB memory stick is not appearing in the list of options. Choose an available drive letter from the drop-down box and then click on "Browse." Find the location of the memory stick and then click on "OK." Close the "My Computer" window and re-open it to access the memory stick.
  • Oct 26, 2009 | Electronics - Others
    Sep 01, 2009 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
    Card reader not working
    Try putting your memory stick on a usb port on the back of the cpu. It may work. Usb ports on the front of the cpu and card reader may not work with all memory sticks
    Dec 17, 2008 | E-Machines eMachines Desktop PC
    Up loading music, Vids, Pics, Themes
    get a memory stick duo of any Gigabyte size you want, Turn on the psp and insert the memory stick duo.Navigate to SETTINGS, under SETTINGS scroll to the SYSTEM SETTINGS and press the X buttom. system settings will appear, then scroll to the FORMAT MEMORY STICK and press the X buttom.
    a message will appear and select yes, this will format the memory stick duo and create folders like MUSIC, VIDEO ,PICTURES etc. required by the psp.
    restart the psp system and you are good to go. remember to save MP3 songs you want to play on your psp to the MUSIC Folder on the memory stick duo when you connect it to your computer in USB mode. if you want to play WMA format songs, navigate to system settings and select the ACTIVATE WINDOWS MEDIA AUDIO(WMA), make sure you are in a wireless hotspot to connect to the internet to activate WMA playback.
    online manual for psp: click on the link. http://manuals.playstation.net/document/en/psp/current/index.html
    Good Luck.
    if you need more help comment me back.
    Aug 08, 2008 | Sony PlayStation Portable (PSP) Console
    Usb cable
    Just like sorta of add-on to szwaan's answer:
    You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
    if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
    Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
    Electronics - Others Logo
    44 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
