Question about Zodiac Nature 2 Cra30 Replacement Cartridge
Zodiac LM3 40 can set timer but digital reading says NOT USED and timer does not turn on
2 Suggested Answers
SOURCE: zodiac clearwater LM3-15
Just found the instructions for this at this address
http://www.zodiac.com.au/media/25135/zodiac%20lm3%20owners%20manual.pdf
worked beautifully....good luck.
Posted on Oct 17, 2008
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
How do i set my timer for my pool pump
10-20-12
The 240Volt residential titan pool pump does not have built in timer.
So timer is installed on the electric line going to pool pump.
Copy following links to help identify timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Boxtype.html
Also add a comment and describe timer in detail for possible help.
Oct 20, 2012 | Zodiac Pool & Spa
Garrison RCT100 DIGITAL TIMER
Yes.
Timers usually don't last more than a few years, unless you buy the heavier duty box timers that last decades.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Dec 20, 2011 | Hardware & Accessories
I can't set my Malibu Low Voltage 200-watt Digital timer
Problem is not identified.
Is timer not functioning? Or are instructions confusing?
Add a comment with more information and include which timer you have.
There are 3 different digital timers and each works similarly.
Open following link to identify timer.
Also scroll to top of page to read advisories and tips to prolong life of power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Each of these timers is dawn-dusk timers that turn ON at dusk.
Then you can set options for how many hours the timer works until lights turn OFF.
Oct 04, 2011 | Hardware & Accessories
How do I wire a 220 volt two speed swimming pumpmotor using aground fault circut creaker
More information is needed.
Is the circuit breaker 240Volts or 120V?
Is the pump 240V?
What kind of switching timer is connected to pump?
What color are your wires?
Read information below and then add a comment.
Typically, the pump is 240Volts.
Pump is wired to mechanical timer with NO NC contacts for example GM40 series:
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour%207%20day/gm40%20series%20multi-voltage%20time%20switch.aspx
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM
The timer sends power to one speed or the other speed but not both speeds at same time.
Timer can be mechanical or digital.
Mechanical timer is used if pump is supposed to be ON at all times.
Digital timer like P1353 is used to control pump more exactly.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
See example1 for 240V
http://waterheatertimer.org/images/P1353ME-2-speed-motor-500.jpg
Timer is rated or set for 240Volts.
GFCI protected 240Volt line leaves circuit breaker and goes to timer. Then timer and pump are both protected.
Jul 09, 2011 | Electrical Supplies
I can not get the timer to automatically turn off and on UTILITECH 7-DAY DIGITAL IN WALL TIMER
Utilitec sells two different 7-day timers.
Open following two links to identify timer, see manual, and read wiring instructions:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
From description of problem, it sounds that timer programming is not correct.
Each event needs ON time and OFF time.
If ON time is set.but OFF time is not set, then timer will turn ON and never turn OFF.
ON and OFF times must match days with each other.
Also if programs overlap or conflict, timer will not operate as expected.
I think instructions for both timers say that programs can be reviewed by pressing PROG button.
Re-read manual carefully.
Write out parts of manual that are confusing.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 09, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
How do I close the stem on a zodiac watch?
Your watch do not have screw down crown feature. You can only pull out or push in that crown.
Check instructions for yourself from the official Zodiac document here:
https://www.zodiacwatches.com/images/pdf/zodiac_watchinstructions.pdf
Rate me, please.
Mar 14, 2009 | Zodiac "Sea Dragon" Watch
Zodiac clearwater LM3-15
Sep 07, 2008 | Zodiac Nature 2 Cra30 Replacement...
Zodiac Nature 2 Cra30 Replacement Cartridge Logo
62 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
