Question about Estate ETW4400XQ Top Load Washer
Water leaks on the floor
Seems loke water over fills and when agitating the water flys all over
I have a Whirlpool washer that's leaking water onto the floor. Jason Harris told me to look under the heater i don't know where the heater is.
There is no heater on that machine.
Does the water leak as soon as you start the fill cycle or does it start to leak when the water level gets up to the agitator?
Oct 20, 2012 | Washing Machines
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The washer fills but before it agitates the water pumps out and then keeps repeating this process. Once in awhile it agitates for a short time.
This is an easy fix. Your drain hose must be 30 inchs above the floor. If it is not at least 30 inchs above the floor, gravity will drain out the water at a given point and then the water level will drop sufficiently for pressure to cause the motor to stop and the water valve filling again. Simply make an adjustment on the placement of the drain hose to prevent the auto siphoning of the drain hose.
Dec 30, 2009 | Washing Machines
? Overfills. Doesn't seem to acknowledge water
put the washer on fill,now turn it off,if the water stills fills it is a bad inlet water valve,if it does not the water level hose might have come off or the water level switch is bad,let me know what you find-mike
Apr 04, 2009 | Kenmore Washing Machines
Water leaking when being filled .
leaking while the washers off is a normal problem.check for corrosion or crack on the outer tub.
check the water supply connections and the drain hose.also make a check for the tube seal and tube bearing.these are the only possibilities for a water leak.
Dec 12, 2008 | Kenmore 24902 Top Load Washer
Magic chef washing machine
Water is leaking all over the floor from the bottom of the machine when it is filling up. Can you tell me how to fix this problem.
Oct 23, 2008 | Washing Machines
Leaking
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Feb 25, 2008 | Solis Master 5000 Espresso Machine
My washer, while draining, leaks from the bottom.
remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
May 31, 2007 | Whirlpool LSQ8000 Top Load Washer
Estate ETW4400XQ Top Load Washer Logo
16 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
