Question about Radio Shack Radio Communications
Cat no 21 1679
Need specs, price and availability for a ni-mh charger, possibly new batteries too- can you help?
Quack
  • 542 Answers
SOURCE: Can only Epson brand Ni-MH batteries be used?
I own a variety of NiMH batteries and chargers (both the fast (ie. like the Epson "3 hour") charger and slow or "trickle" overnight chargers for AA applications. As far as I can tell, all NiMH battaries, chargers and appliances (eg cameras) are interchangable. Just follow the Charger Manufacturer's instructions for how long to leave the batteries in the charger. The time required for full charging will be dependent on how much charge is left in the batteries, as well as on the rated capacity of the particular battery used (mAh or "milli amp hours").
Posted on Sep 13, 2005
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
eradiostore
  • 1654 Answers
SOURCE: Battery charger
The battery is shorted out. You will need to replace it.
Posted on Jun 26, 2008
SOURCE: Columbia Walkie Talkies - Model: GM3W - need batteries
I have the same radios, working, with a charging dock - no power cord though. I was just going to try and sell the set. usmc_nevarez@yahoo.com
Posted on Dec 22, 2008
SOURCE: Panasonic CD PLayer SL-CT520 Rechargeable AAA Batteries
Hey this is RaulFixall. You can fix this problem by naking the batteries, I'm mean by taking apart the plastic that cover them. You'll see that the led charging will turn on.
Posted on Jan 03, 2009
NI-MH D 14.4V 8000mAh Charger Hack. I need an alternative charger like charging on a car battery?
NI-MH batteries a re very different than car batteries and even tho voltage may be similar, you risk destroying your battery, camera or worse, an explosion. Your batter may only need a limited amount of amperage to charge (likely not much more than 1500ma or 1.5 amp) a car battery charger may put out twice or even ten times that much - hence the explosion risk! Also these kind of chargers detect when your battery is full and will quit charging or switch to a maintenance mode. I'm afraid you're pretty much stuck with using the charger meant for it.
May 08, 2016 | Cameras
Alternative battery charging
you cannot use any charger that is not used to charge ni-mh batteries car batteries charge at a rate of 5 amps minimum and if you do it will cause serious damage to the charger and batteries
if you want ideas , talk to a battery shop but unless it is designed to charge 14.4 volt ni-mh batteries-- forget it
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
Do you know where I could find a user guide manual for a NEXXTECH Ni-Cd/Ni-MH 2300033 battery charger?
Radio Shack 230-0033 appears to be the same charger.
I have this charger (Nexxtech branded, model 2300033) and the specs all appear to line up. However, I don't have the manual.
http://support.radioshack.com/support_electronics/71094.htm
Aug 23, 2012 | Cameras
I lost the battery charger for the BigFoot toy. Can I buy one?
I know you can get these on Ebay. Also most NI-MH 9 volt battery charges will charge this battery pack. You can use a 9 Volt Snap Battery Connector with Alligator Clips to bridge the connection between the battery pack and the NI-MH 9 volt batter charger. This is how I charge this battery pack now. You can probably get the 9 Volt Snap Battery Connector with Alligator Clips at a radio shack or on Amazon... as well as a NI-MH 9 volt battery charger.. don't hook up the leads backwards :)
Aug 10, 2011 | Mattel Fisher-Price Imaginext Big Foot
My Kodak Easyshare Z1275 has short battery life. sometimes even newly charged 2600 MaH batteries cause problems. Powers up, lens extends, opens screen to set time and date then powers down. Sometimes i can...
wait, do you have Li Ion batteries or Ni MH?
I think that Kodak recommends Li Ion batteries which have a higher voltage on them.
I got some generic Li ion battery packs off of Amazon.com, with better specs. than Kodak, and they work fine for my Easyshare z1485 IS camera.
It cost me like $80 to get the charger and two battery packs that are Li Ion, but it's worth it.
My battery packs are rated at 2000 mAh 3.7 Volts each. It's the voltage that counts. You see, if you would split that in half, the voltage for each AA battery is 1.85V which is much higher than the 1.5V that regular Alkaline or Ni MH batteries are rated at.
I tried Alkalines, and Ni MH to no avail. But, the Li Ion batteries, did the trick for me.
Good luck on this 'repair' or battery upgrade.
Jul 23, 2010 | Kodak Cameras
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Have a easyshare dx 4530 camera. looking for dock 11 or equivilant?
Since the Kodak EasyShare Camera Dock 2 is no longer available, you can use a KODAK Ni-MH Rapid Battery Charger K4500-PC-C+1 instead.
Item number is 1717610.
You can also use any brand of battery or charger as long as it is Ni-MH.
Jun 27, 2009 | Kodak EasyShare DX4530 Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Cannot power on to take photos
I found that one has to use their batteries of at least 2100mAh and NI-MH. I recharged my batteries removed the new ordinary alkaline batteries I had put in and BINGO IT WORKED. Just to prove the point I put in another set of Alkaline batteries No good. It must be that NI-MH Batteries rated at 2100mAH have more power (or one can draw more currentat start up) a battery guru could maybe veryify my conclusions. Anyhow try NI-MH batteries and see how you go. Best of luck fredlich
Aug 15, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Radio Communications Logo
89 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
