Question about Music
I am after a manual for a 'Gold Star digital Piano, GEP-s620'
I have a Yamaha G2 baby grand piano, and can't locate the serial number. Can you tell me where I might find it? Many thanks
"The serial number on YAMAHA GRAND PIANOS is stamped on the gold colored plate located inside the piano"
Here's a like that I hope will help: http://ca.yamaha.com/en/support/serial_numbers/
Jul 29, 2016 | Yamaha Music
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
I have a Technics PR-305 Digital Piano It was working at the End of October, but around the beginning of November 5 my Technics PR-305 Digital Piano made a loud humming sound, then it quieted down, I
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
Nov 26, 2014 | Casio Music
Midi settings
You have to plug in the laptop sorry to say. Think of it as a piano that can be used as a midi controller.
Jan 29, 2012 | Williams Allegro 88-Key Digital Piano
Hi where can i get a service manual for an fp-8 roland digital piano?
Here's a link to the Owner's Manual
for a service manual, you're probably going to have to contact Roland directly, since they don't even list the fp-8 on their website. Service manuals for their other products only run about five bucks for a hard copy, i believe. I'm sure you can get to the right place through here: http://www.rolandus.com/corporate/contact_us/
Mar 19, 2011 | Roland Digital Piano FP4 Black With Stand...
The keys do not allow the voluem to change (piano to forte)
Read page E13 of your manual about setting "touch"... You probably have inadvertently turned it "off" so there is no velocity variation of loudness.
If you don't have a manual, download it here:
http://support.casio.com/pdf/008/PX700_e.pdf
Jan 03, 2011 | Casio Px700 Digital Piano
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Sep 21, 2009 | Music
Music Logo
59 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
