Question about Music
Looking for a 'Gold Star digital piano GEP-s620' manual
Where do I get. Manual for H Star H P-4digital piano
Try Googling (H Star)(HP-4)(manual) without parens.
Oct 12, 2017 | Music
I have a Yamaha G2 baby grand piano, and can't locate the serial number. Can you tell me where I might find it? Many thanks
"The serial number on YAMAHA GRAND PIANOS is stamped on the gold colored plate located inside the piano"
Here's a like that I hope will help: http://ca.yamaha.com/en/support/serial_numbers/
Jul 29, 2016 | Yamaha Music
I have a ronisch upright piano made in Germany serial no 48906 how old is it and would you know a price
cant help with the serial number
if tuned casing and keys and strikers are in good condition
if buying from a commercial piano seller price 5 year guarantee
approx
Catalogue
7000 pounds UK
$6000 AU
The Ronisch piano has long been a favourite among piano teachers due to its fine, clear tone and highly consistent manufactured quality. Anyone looking to get a Ronisch is advised to look for instruments made before the second World War, as the original factory in Dresden, Germany was destroyed by allied planes in the latter stages of the war.
All of the manufacturing equipment was lost.
The factory was re-established in Leipzig after the war, but has never manufactured pianos of the same tonal beauty as did the original.
Carl Ronisch, was one of the foremost pioneers of piano-building in his time. He was first to use a full cast-iron plate in the piano, employing five struts and completely covering the wrest-plank (pin block), which for the first time, allowed a high-tension scale.
This is considered the beginning of the use of full cast-metal plates and is today, standard in the industry.
Ronisch instruments have won gold medals in the world exhibitions in Sydney, Amsterdam, Melbourne, Chicago and Paris.
Jul 04, 2016 | Music
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
I have a Technics PR-305 Digital Piano in which I play on. I took apart the Digital piano to get to the rubber contact to clean them. later on I went to turn on the piano and it didn`t work.
Attempted to clean? Not a good idea obviously...Take it apart like you did before and look at the wiring and imagine that you can divine the thing to reveal some logical explanation. If you used a contact cleaner or spray to clean, that could be death to that piano my friend.
Dec 12, 2015 | Music
Where can I find owners' manual for digital piano
what piano what model
look at the label at the base
and post this details please..
Jun 04, 2015 | Music
I have a Technics PR-305 Digital Piano It was working at the End of October, but around the beginning of November 5 my Technics PR-305 Digital Piano made a loud humming sound, then it quieted down, I
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
Nov 26, 2014 | Casio Music
Need help in choosing the best digital piano you can recommend for me for A budget of 2500-3000 usd
The Korg SV188 has stunning realism in the Grand Piano arena. It uses a 12AX7 tube in the preamp output for that classic analog warmth lacking in so many garden market digital stage pianos these days. It has weighted hammer action and carries a price tag of $1,699.00 at American Musical Supply.com They even throw in a extra years coverage at no cost. The Yamaha MOXF6 88 key (same price) is another fine grand piano that wont disappointed but be prepared for a large learning curve learning all the rest of it functions, there are plenty to chose from. Roland wins hands down with its RD300nx, $1,799.00 and the RD700NX $2,699.00 simply the best digital stage pianos money can buy . Look up the specs at AMS
Jul 28, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Sep 21, 2009 | Music
Music Logo
80 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
