Question about Chevrolet 1992 Chevy Pickup Body T E Maxx Rock Crawler Rc Truck
My 92 K1500 5.7L TBI has a high idle and when at operating temp it wants to die in drive
My truck starts with high idle then when wormed up it while driving it wants to die. starts fine but when it gets worm it idles down and wants to die in park
    Problem Solver:
  • 6 Answers
Could be a voltage problem or an idler pulley problem.
Posted on Nov 23, 2013
1988 Suburban with 5.7 TBI runs fine until warms up. Goes to fast idle and when it comes off fast idles won't start back until cools down.
Lets start at the beginning. Is the check engine light on ?
You have an idle air control valve which could be sticking open or shorted to ground. You should be able to unplug it to test. There also could be a gasket or hose that is opening up and causing a huge vac leak.
Aug 06, 2014 | 1988 Chevrolet K1500
High idle
mine did same thing and the cause was that the TBI gaskets were shot , mainly the one right on top of the unit but below the injectors
Feb 21, 2014 | 1991 GMC Sonoma
I have a 90 silverado 5.7 an it just started to idle very high then low cutting out popping an dying on me. I noticed it will start an run fine until it gets to operating temp. Then it acts like sumone us...
Have you tried cleaning the MAF sensor. This sensor is by the air filter box. The mass air flow sensor has to be cleaned with a special spray that you can get at any auto parts store. Do not, I repeat do not use carb cleaner this will ruin it. It is basically a thin filament housed in a grid where the air flow goes through and if it gets coated by dust, oil, or burning to rich black soot this will throw the signal off just enough at the computer.
Nov 17, 2013 | Cars & Trucks
High idle
It's probably one of two things , a vacum leak or a bad ground.
Dec 23, 2012 | 1989 Chevrolet C2500
My 1998 Dodge Ram 1500 idles high upon starting it.
Check temp gauge if It doesn't get to normal heat range it won't idle. Your thermostat needs replacing.
Aug 23, 2012 | 2001 Dodge Ram 1500 Truck 2WD
1990 chev K2500 5.7 TBI driving down highway and just quit like i turned it off. pulled over will idle fine but off idle tries to die. after shutoff for a few minutes starts an has throttle respose for a...
Fuel injection needs 20-30 pound pressure to fire the injectors. Try to check pressure before filter. If its low your pump is no good. If its ok then you have pressure drop after the filter. Filter on backwards or clogged.
Nov 25, 2010 | 1990 Chevrolet K2500
92 gmc 1500 4x4 when at operating temp starts poping threw tbi i have chaned wires,cap,rotor,ign mod,coil,temp sensor,idle air controll valve oxygen sensor.
Your egr.valve may not be functioning good chanse its got carbon build up, or there is no vacume to it, remove it and clean it with carb cleaner, both the valve and the intake.
Dec 24, 2009 | 1992 GMC Sierra K1500
High idle
You could have a bad gasket under the TBI that is allowing uncontrolled air to enter the engine or an Idle Air Control Motor that is not working properly.
Aug 03, 2009 | 1992 Chevrolet K1500
Idle probs
Check your idle control valve. You might have to replace it, 80-90 bucks new. Or see if there is an air leak from the intake manifold. had the same problem.
Jun 04, 2008 | 1992 Honda Prelude
Chevrolet 1992 Chevy Pickup Body T E Maxx Rock Crawler Rc Truck Logo
74 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
Steve
Steve
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
