Question about Microsoft LifeCam VX-3000 Web Camera
How to change the date and time settings in anyka MMC disc USB device
I use spypen 16gb i required anyka usb web camera driver & time.txt for change time dt. for my spy pen
How To Update Time Automatically of Spy Pen Camera
1)
Connect the camera to computer via USB cable
2)
Download GetSysTime at http://diganet.net/downloads.html
3)
Click GetSysTime.exe to update the date and time, the
time of the camera will synchronize with the time of computer after restart of
camera upon reconnecting.
Nov 27, 2010 | Computers & Internet
Memory not readable by PSP or Computer. HelP!
Dear Friend,
you have to check the Following
  • Make Sure Your MMC is NOT PASSWORD PROTECTED
  • Your Card Reader properly Connected to PC(Make Sure GOOD in Condition about the Reader)
  • Properly Inserted MMC to READER
  • Change USB port if Still Not Detecting
  • Try another MMC to Reader
  • Reinsert your MMC
  • Reboot your PC
Remove Lock of MMC(Lock might be in Left Side of Your MMC).Still you have Problem Please Change your CARD READER/MMC ...
YOu are done...Solved.....
IS this HelpED you ... Do RaTe mE...
you can Feel Free contact me... Thanks for Using FixYa
Apr 04, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
ClearChat Pro USB headset asks for driver upon install
  1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
  2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
  3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
  4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
  5. Open the Control Panel, System, Device Manager.
  6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
  7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
  8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
  9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
  10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
Oct 20, 2009 | Logitech ClearChat Pro USB Headset
Need a driver anyka web cam
First you need to go on manufacturer site, and there is an option to download driver with the help of your webcam model.
Thanks for using Fixya…
Sep 16, 2009 | Computers & Internet
I need anyka usb webcam driver
After googling for quite some time I found one finally and added it to my Windows Live SkyDrive. I've put it in my Public folder for all users to download here
http://cid-b719bca07f035283.skydrive.live.com/self.aspx/.Public/Anyka%7C_PC%7C_Camera%7C_Driver.zip
Aug 13, 2009 | Computers & Internet
What after Low-level Format?
hello
when turnon my mp4
i see bios 3221-9320-mlcv7.1
and i can not use of mp4
Mar 20, 2008 | Audio Players & Recorders
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Oct 30, 2006 | Samsung Prostar 816 Phone
Microsoft LifeCam VX-3000 Web Camera Logo
186 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
