Question about Keurig Elite B40 Coffee Maker
Keurig won't work if there is a K-cup in however water flows through perfectly without it?
  • Susan Zukauckas
    Susan Zukauckas Nov 24, 2013
    Was asked to add more comments but it is pretty well explained. There is no clog, used paper clip, compressed air and all lines are clear. When put into operation hot water will flow through just fine & works correctly HOWEVER, when a K-Cup is placed in no water disperses through. It just makes all the loud brewing sound and nothing happens. Take the cup out and then again it works perfectly!
    Master:
  • 240 Answers
TRY..Lifting up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be.
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO IT:
Pour approx 48 ouncs of white vinegar into the water resevoir. PLacew a large mug on the drip tray, DO NOT use a K-Cup, press the brew button. Pour contents into sink. REPEAT this process until the ADD WATER idicator light, lights up. Let brewer stand for at least 4 hours while it is on. Discard any residual vinegar in the resevoir and rinse thorughly.
FILL the resevoir with fresh water. Place a lage mug on the drip tray and hit brew, again NO K-CUP, pour contents of mug into sink.REPEAT until "ADD WATER" is indicated.
YOU MAY NEED TO REPEAT THE RINSE CYCLE IF YOU NOTICE ANY RESIDUAL VINEGAR TASTE
GOOD
Posted on Nov 25, 2013
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
tgmusicgirl
  • 91 Answers
SOURCE: The water will not go through the pod to make the coffee
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
Posted on May 18, 2010
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Posted on Oct 07, 2010
  • 40 Answers
SOURCE: MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
heatman101
  • 43501 Answers
SOURCE: My keurig is not filling up the cup with water,
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
-llllllllllll
Posted on Feb 26, 2011
My keurig 2.0 is overflowing.What is causing it and how do I get it to stop?
I guess I would ask if the other sizes work correctly?
you did not say what over flows , the coffee cup or the Keurig basket.
if it is the basket then the holes that drain into coffee cup are clogged. You need to run (without a Keurig coffee cup) just hot water. This should be done a few times.
Oct 04, 2016 | Keurig Coffee Makers & Espresso Machines
Keurig troubleshooting
if off warrenty these machines are basically throw away. sorry
Jul 20, 2014 | Keurig Ultra In Home Single Cup Brewer...
Won't pull water up into k cup, instead hot water flows back into the reservoir.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 13, 2011 | Keurig Platinum B70 Coffee Maker
My coffee maker went from making a perfect cup of coffee to a flavorless cup over night. I use bottled spring water. It does not say it needs descaling. I drained the machine and still the coffee is...
Hi, The bottom needle is plugged.... this causes the water to flow back up out the top of the cup rather then flowing through the cup...
heatman101
Sep 05, 2011 | Keurig Elite B40 Coffee Maker
All of a sudden my mom's Keuring B40 won't make a full cup of coffee.
Mine started to do that about a month ago. I would have to brew multiple "cups" just to fill one coffee cup. I ran several cycles of the largest cup, without any K-cups, to clean out the small metal spout. After about 3 hot-water cycles, it worked fine. I do this periodically, as I don't use the Keurig daily, so some of the residue builds up between uses.
Aug 15, 2011 | Keurig Elite B40 Coffee Maker
Water flows through fine without a kcup, but only trickles out to fill a 1/3 cup with kcup. what should i do? thank you.
heatman101
Aug 05, 2011 | Keurig Ultra In Home Single Cup Brewer...
Sounds like it draws water, but won't make a cup in the morning. I usually have to power cycle a couple of times and then it works fine rest of day.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jul 08, 2011 | Keurig Platinum B70 Coffee Maker
My Keurig Platium truckles water through a cug, however, it flows great when the cup is removed and run without a cup in place??
heatman101
May 08, 2011 | Keurig Platinum B70 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
120 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
