Question about Lifetime Acer TravelMate 8371-944G32N Replacement Laptop Power AC Adapter / Charger (91812051663)
Acer travelmate tm8371-944g32n Black screen problem
Second monitor only works in safe mode
Acer travelmate 4230 black screen but can still see whats on screen and works perfect on external monitor. How to fix??
Still using an external monitor because the screen on the laptop it out of services. Try to found the same screen on the internet an buy it. Remenber a new sceen is one of the most espensive part.
Oct 30, 2010 | Acer TravelMate 4230 Notebook
The Acer travelmate 240 boots up and after the Acer screen goes to the windows didnot close properly screen and then back to the Acer screen. How to boot it up ?
First try to start in safe mode:
Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Apr 03, 2010 | Acer TravelMate 240 Notebook
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer TravelMate 3260-4874 Notebook
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Windows did not start successfully.
hi asharah,
Ur operatibg system was corrupted ,u reinstall the operating system (xp ) .
Pl try it
Regards
Was this soultion useful? give the appericiation by rating it.
Mar 27, 2008 | Acer TravelMate 2300 Notebook
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Mar 03, 2008 | Acer TravelMate 2300 Notebook
Lifetime Acer TravelMate 8371-944G32N Replacement Laptop Power AC Adapter / Charger (91812051663) Logo
53 people viewed this question
Top Lifetime Computers & Internet Experts
Corey Bartlett
Level 1 Expert
Paul Bade
GG TECHNOLOGIES
Are you a Lifetime Computer and Internet Expert? Answer questions, earn points and help others
