My amp lost ground and my amp won't turn on I need
My amp lost ground and my amp won't turn on I need this round black part to fix it but I'm not Shure what the part it
  • 24 Answers
What round black part are you referring to here? Is it the black cylindrical thing in the middle with a silver band on the right side of it? That's a diode. It has a polarity (+-). Normally they have markings on the body (part number or value). If you could take it off the board, the markings might be hidden under the part. Or just bring the part to an electronics parts store and let them find the part for you.
Posted on Nov 23, 2013
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Shure pgx2 won't power on
Contact Shure for Repairs. www.shure.com/service
Jan 13, 2012 | Shure PGX-2 Wireless Handheld Microphone...
Shure PGX2 wireless mic won't turn on
If it won't turn on, it will need to be sent to Shure for repair. www.shure.com/service
Aug 29, 2011 | Shure PGX-2 Wireless Handheld Microphone...
Bulbs have been replaced and fuses but right turn and marker won't work.
There is a Black somewhat rectangular connector with 3 wires (Black - Yellow/Black, & Tan) at the turn signal/marker light.
Turn on the parking lights & your turn signal.
Using a test light or a multimeter (with the ground wire for both on a good ground) check to see if you have constant power to the Yellow/Black wire, and intermittent(flashing) power to the Tan wire.
If you do, then check to make sure the Black wire is grounded properly.
Jan 07, 2011 | 2002 Jeep Wrangler
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
you rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Oct 07, 2010 | Audiofonics Car Audio & Video
Shure SM57 - 3 wires:blue, red, black. Which color goes to which pin?
You need a multimeter to check this.
The black wire is customarily ground and should go to the pin that measures a dead short to the metallic case of the mike. The red and blue wires are connected to the secondary of a balanced transformer and can be interchanged with no problem.
You can get a line drawing of the mike connector correctly identified in the user guide and that can be downloaded here:
Shure SM57 manual
Nov 17, 2009 | Shure SM57-LC Professional Microphone
1991 Jetta: real running lights and intstrument panel lights not turning on when headlight switch turned on; headlights DO come on. What is causing this?
on older car ...most of time its a ground probleme ...all ground goe's for powering the head lignt ,im shure if you only put your day lignt on ...your panel lite normaly! not much to do about that ...need to track the probleme down and fix the ground ...not easy and could take long unless you can maybe try to put a new ground staingt to your head lignts!
Jul 21, 2009 | 1991 Volkswagen Jetta
Technics SL-D303 motor noise
CHECK TONEARM GROUND TO SIGNAL GROUND WIRE OR SOCKET FOR CONT.
Mar 13, 2009 | Technics SL-1200MK2 Turntable
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Can't get my amp to turn on
You need to confirm that you have sufficient B+ and remote turn-on voltage.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
 Grubhead
Grubhead
