Question about HP LaserJet 2550Ln Printer
HP 2500N I put in a new drum and cartridges and now it prints odd, what should be black is pink, colors are off...Does anyone know how to clean these printers or run any kind of maintenance from a MAC platform? THANKS!
    Genius:
  • 1,089 Answers
Don't think that cleaning will clear up a colour shift problem. Upgrade the firmware to 20040930, if it isn't already.
Posted on Apr 07, 2010
My Officejet R80 prints only in red and black; Any suggestions
Color cartridge dried up..Perform clean cartridges through printer properties.. check,,no result, replace color cartridge..
Sep 01, 2012 | HP OfficeJet r40 InkJet Printer
I put new print cartridges in my 960c printer. They are hp 78 for color and 45 for black and white. my orange ink light will not stop blinking. It is not printing
I have an HP DeskJet 1220C that has been working fine for two years now. All of a sudden it can only print in pink and black. It is driving me crazy. I have tried the following without any success:
1. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Is there a cure, or is it time for a new printer?
Aug 25, 2011 | HP DeskJet 960c InkJet Printer
How to remove the cause of a black line a HP Laser Jet printer model 4250 has produced down the center of everything printed for a long time? Thorough cleaning has had a very little effect.Last week I...
In cases of print quality issues you should always start with the imaging drum. In this case the toner cartridge. Make sure it is not a re-manufactured or refurbished toner cartridge. A lot of times when someone refurbishes the cartridge they don't replace the imaging drum (the blueish green drum under the shutter). Check for toner stuck or burned on the drum. If there is you need to replace the toner cartridge
If there is no toner stuck or burned on the imaging drum then you more than likely you will need to check or replace the Fuser in the back of the machine. The back door of the machine comes out easily enough and the fuser clips into place. **Be careful it doing to be hot.** Remove the fuser and check the rollers inside for burned toner or damage. If so replace the fuser .
You can purchase a Fuser Kit from HP or find a refurbished fuser from Depot America or OrionMarket.com for a lot less.
Aug 16, 2010 | HP Office Equipment & Supplies
Do the reset chips really work on the cartridges of HP 2500N laserjet printer
Yes, reset chips really work on laser printer cartridges, if you have a know good source for the chips and if you know what your doing, you can't put a new chip on an old cartridge, the chip is what registeres how may prints you will get out of the cartridge if you put a new chip on an old or 1/2 empty cartridge of course it will say it's full but then try and print.It will register as a full cartridge but it can only print with the amount of toner that is actually left in the cartridge, be careful there are alot of remanufactures out there that don't put new chips on or that do but don't fill the cartridge full, or replace all the wipers and drums, they just dump some toner in and say here you go, Only buy your remanufactured cartridges from a reputable company, do your research on them first or you'll be sorry
Aug 14, 2010 | HP LaserJet 2500N Printer
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Jul 13, 2009 | HP DeskJet 990cxi InkJet Printer
Hp psc 1510 prints reddish-pink color
the photo come out pink and i buy yesterday can you help me hp 1510
Oct 30, 2008 | HP PSC 1510 All-In-One InkJet Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Computers & Internet
Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
May 11, 2007 | HP OfficeJet t45 All-In-One InkJet Printer
HP LaserJet 2550Ln Printer Logo
63 people viewed this question
Clive
Clive
