Question about Philips Sonicare AirFloss
No liquid from handle - Philips Sonicare AirFloss
What happens if you would add a charge to a running system that has a low charge on a 404a system and you charge thru the suction as a vapor. I had a memory lapse and have charged 410 systems as a liquid...
as long as you recovered the charge, pulled a vacuum, changed the filter/dryer, and added the correct amount of refrigerant as a liquid, you should be good to go.
Jun 28, 2017 | Hoshizaki Freezer Commercial Ice Machines...
Tip
Your laptop do not need a drink
Liquid is a laptop killer of the first order. Never ever, ever allow any water, soda, coffee, tea or any other liquid near your laptop. If you should forget this, be ready to shell out big bucks for a new system. O.K., suppose you get a splash. The first thing to do is disconnect the AC adapter and REMOVE THE BATTERY! DO NOT TRY TO POWER IT ON TO SEE IF IT WORKS! Place the laptop on the side where the battery came from and allow it to drain. It should dry in about a week. O. K., in a couple of days. I would strongly suggest that you seek a qualified repair person to check it out BEFORE you try to power it on. This is because although the liquid may be dried, the residue from liquid can corrode and damage the leads of the components. Given time it will eat the leads off of the IC's and even the runs off of the mother board. Most times, if handled early, this will only cost the labor. But if not handled properly, the keyboard, motherboard, video card, LCD and/or just about everything else could be damaged. Note every laptop is different and the advice given is only a general example. All advice given is not meant to suggest any outcome. Anything you attempt after you spill liquid on your laptop is "at your own risk"
on Apr 25, 2011 | Computers & Internet
My 2006 HHR has check engine light constantly on and now has liquid dripping from the right underside of the dashboard. Is this related or seperate issues? Also, the inside door handle just broke off in...
does the liquid have color if perfectly clear its condensate from AC evaporator, the drain may be blocked and need clearing. A red/orange color indicates the heater core or lines to it are leaking Dex-cool. As for the CEL have a auto parts store, O'reilys, AutoZone scan for codes and get back to me. The door handle will take some surgery especially on getting the interior panel off, hidden screws, wire connectors. Find a reference sheet for that
Sep 17, 2012 | 2006 Chevrolet HHR
How do you purge the liquid from a shopvac
If you have picked up liquid with your shop vac , you then need to release the handles on the side and dump the liquid out of the tub. Do not worry about the top part, the ball will float up and shut off the air so no damage will occur.
Also change the filter and bag if you have either inside when the liquid is picked up.
Heatman101
Mar 14, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
PROheat cleaner model #8930 will not despense liquid.
yes if it sprays from the hose its the heater clogged its in the handle if no spray replace belt check on rinse only
Dec 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My indesit washing machine collar has come off how do i put it back on
Put some liquid soap, like Dawn, around the area that will be against the opening, and push it back on, the seam, if there is one, should be at the top, prevents leaking. The soap will help to keep the collar in place....this works for vacuum cleaner handles too...if it slips off, rub some liquid soap on the top of the handle stem, and inside the plastic handle...slide it on and let it dry!! Takes about 24 hours for it to dry.
Aug 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bleach & Softner not emptying
What "form" are you using? liquid, gel, powder? try using a different type and lean towards the more liquid forms if your washer can handle them, ie move from powder to gel or liquid, and from gel to liquid. Hope this helps.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Philips Sonicare AirFloss Logo
89 people viewed this question
Top Philips Sonicare Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Philips Sonicare Health and Beauty Expert? Answer questions, earn points and help others
