Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
Need new control pod for companion 5
Dorp too many times
    New Friend:
Can you explain the problems you are having for dropping it many times? Is it just physically damaged from outside / The cuircit inside is broken / Completely dead? Would be easier for me to solve the problem. Few days ago I bought a new Control pad from ebay which was $85. See, if the circuit is broken inside or the cable is damaged surely we can come with a solution.. I have a working control pad Cuircit and other spare parts.. so if u can find out the part needs to be replaced then i am sure u can cut down this expense. Thanks.
Posted on Mar 07, 2014
5 Suggested Answers
SOURCE:
  • 10 Answers
SOURCE: Where Can I purchase a bose companion 5 control pod?
you have to call customer service at 1-800-367-4008.Run about $35.
For the broken cable, have you tried to fabricate a new cable for it?
Posted on May 25, 2009
fixyathing
  • 341 Answers
SOURCE: Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Posted on Aug 12, 2009
SOURCE: Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Posted on Sep 15, 2009
SOURCE: Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Posted on Jan 26, 2010
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Anyway to use Bose companion 3 system without the control pod?
had the same issue. Trial and error - I tried shorting every pair in the control pod dock with a paper clip. Turns out it is totally possible to bypass. You need two: top row, right side to third row, one from the right (below it by two spaces), and second row (there are only two in the second row, connect them). One tells it to turn on, the other passes audio through. I'm only getting sound from the right channel, so probably need to connect one more pair...
Read more: Can i operate my bose companion 3 without the control pod? - I lost my control pod. can i go around it. :: Ask Me Fast at http://www.askmefast.com/Can_i_operate_my_bose_companion_3_without_the_control_pod-qna6342714.html#q3658086
Jun 29, 2009 | Bose Companion 3 Computer Speakers
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Jan 29, 2009 | Bose Companion 3 Computer Speakers
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
326 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
