Question about Rheem Prestige Series 3.0 ton 16 SEER Complete System R-410A with 80% Efficient 75k BTUH Gas Furnace Multipoise
Installing Rheem gas furnace, where is the pressure switch and how do i turn it on/off?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
Can you be more specific about which switch, what the problem is and what your trying to do? Thank you.
Posted on Nov 23, 2013
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
Have a rheem furnace/ten yrs old.just replaced thermocoupler and gas valve,furnace will turn on thermocoupler will get red but no heat? whats up?
I know it may sound strange but check to make sure the gas cut-off valve is turned parallel with the gas pipe. If its open, you may have a failed fan proof switch. air pressure from draft induced blower causes the switch to click and open the main gas valve. if this this switch doesn't click(close contacts) the maing as valve will not open to ignite the burners. its a sequence of events that a furnace goes through before it ignites the burner for heat.
Nov 28, 2010 | Heating & Cooling
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
Rheem Classic Series Super Quiet 80 gas furnace problem
I have this same POS model. It is not the thermostat. this model is just garbage and cant wait to get something that works right. i have been fighting this thing for 4+ years now.
Dec 25, 2009 | Heating & Cooling
Rheem RKKA048JK10X Furnace/AC Unit. My rooftop
Mr. Miller,
It may be a problem with the tubing from the inducer to the pressure switches. During the night hours, condensation forms and collects in these tubes preventing the pressure switch from closing when the inducer motor starts. Check these tubes and possibly re-route so there is no sag in the middle. Try to route them so they are as straight as possible. If that is not possible, at the location of the sag, cut the line, put a "T" fitting in and attach a piece of line to the bottom of the tee with a plug to catch the accumulated condensation.
Also, have your service company check the firing rates, gas pressures and temperature rise across the heat exchanger, Any of these can also cause a problem with condensation accumulation in the pressure switch tubing.
Nov 10, 2009 | Heating & Cooling
I replaced my Rheem Ruud 62-24084-82 Ignition Module Control Board in my Rheem gas furnace last year. Has worked great until last night. Now blower purge motor starts but does not go into ignitor cycle. ...
When the purge motor turns on, the controller is waiting for proof that it is running before ignition. On your model I think it a differential pressure switch and it should be in front of the furnace. Should be able to see a pressure or vacuum line running to. If it isnt there there may be a switch inside purge motor. If there is more than 2 wires running to the motor it probable is there. Anyway the controller is waiting for proof.
Nov 05, 2008 | Ruud Heating & Cooling
Rheem Prestige Series 3.0 ton 16 SEER Complete System R-410A with 80% Efficient 75k BTUH Gas Furnace Multipoise Logo
131 people viewed this question
Top Rheem Garden Experts
Dennis Key
Dennis Key
john h
Are you a Rheem Garden Expert? Answer questions, earn points and help others
