Question about Connex 4600 Base CB Radio
Connex 4600 dropping on recieve
Sometimes is keyed up on power up. Receive drops after a few minutes on Modulation breaks up.
  • 141 Answers
Cold solder joint somewhere
Posted on Nov 26, 2013
Mister 44
  • 35 Answers
SOURCE: connex 4600 turbo radio stays keyed up even with
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Posted on Apr 03, 2010
SOURCE: Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Posted on Mar 28, 2009
  • 17 Answers
SOURCE: Need to know the internal mod limiter board number and the AM mod
check www.cbtricks.com
Posted on Oct 31, 2009
SOURCE: Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Posted on Sep 05, 2010
jcameo7270
  • 675 Answers
SOURCE: Connex 3300HP old model. Dead keys no modulation
Try the voltage regulator or the power supply circuit
Posted on Jan 23, 2011
I have a connex cx-3600hp cb and it sounds like it has no power
your power switch it faulty as there is a drop in voltage
does the meters dim down?? then the voltage supply past the power switch it dropping as it draws more current or... the audio ic has damage or one of its associated capactors sometimes a diode can become leeky its used for AM modulation also
Feb 25, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
Connex 3300hp big betty transmits fine on low power setting but when switched to high power hardly any modulation
well fellow truck driver here goes. When you take any radio back to a repair shop they are required by law to set it back to its original settings. I could fix it for you if you ever got to Massachusetts but you need it now so I would tell you this.Take it to a very good cb shop , tell them what went on and that you would like that big radio sound back. thats it.
Mar 16, 2013 | Radio Communications
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
I have a connex 4600 turbo very good radio!! But the other day I keyed up my mic and the radio shut off but came right back on when let go. Do u know what that might be?
check for any loose power connections.. ground connections.. loose coax.. also make sure vehicle is on so not to drain battery down when TXing. if it was off it may have dropped battery voltage down lower than it should... and turned off.. RX doesn't use hardly any ampres..
Mar 28, 2011 | Connex Radio Communications
Connex 4600 turbo. Poor receive. About 4 mi.
Hi there!!
The Connex 4600 Turbo is a very sensitive radio these radios don't work good at all with the stock microphone! The best microphones are the RK-56 and or the Astatic 636L which most people use and you shouldn't get any squeal. And make sure if that you are using an external speaker get it as far away from the radio as you can facing away from the radio so it wont feedback. As far as a Mod kit there are several ways to modify the radio which most are pretty hard and drawn out. but the most easy that used to be used is as simple as a diode placement in the right place which is old school but still works good. You must be very careful as if you are to slightly touch the wrong points the radio could be destroyed and no longer work so caution is to be taken if you don't know what you are doing please don't try it on an expensive radio!! If you want more info on the mod e-mail me
never the less a Modulation kit or modification wont help your Receive it will only help your Transmit signal!!
Dennis
May 20, 2009 | Connex 4600 Base CB Radio
Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
Mar 07, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Engien revs and lights dim when i key up
You don't say how much power you  are running, but it must be quite a bit, or you have an amp you're not telling us about.  By keying up the radio, you're putting enough load on your electrical system to pull the voltage down which causes you lights to dim, rpms to drop, etc.  When you key off, everything goes back to "normal" which means no load so the engine will surge momentarily before it recovers.  Depending on how many watts you are running, you may also be affecting the alternator regulator.  Your alternator may also be a little weak.
Nov 17, 2008 | Connex 4600 Base CB Radio
Frequencies
Feb 01, 2008 | Connex 4600 Base CB Radio
Radio Communications Logo
53 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
