Question about Dishwashers
Dishwasher element wont work
I have a ELBA EDW125X1 dishwasher the element wont work i have checked the resistance of the element it is 27ohms
Elba dishwasher wont drain
why is the dishwasher not washing properly
Jan 12, 2014 | Water Heaters
The dishwasher wont heat up
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jun 25, 2011 | LG LDF6920ST Stainless Steel 24 in....
My miele dishwaher is not heating the water thus not wahsing the dishes properly
heatman101
Apr 26, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
My elba c96df oven has stopped working . The oven lamp comes on but theres no heat . Is it the elements or the thermostat?
Elba Oven not heating? How to replace a Elba fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Elba element How to Repair Home Appliances
Mar 06, 2011 | Microwave Ovens
Dishwasher is not heating water and wont dry dishes.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element for mineral deposit on it, clean the deposits using a soft brush and a cleaning solution (Don't scrub the element hard). If this doesn't resolves the issue then remove the panel and examine all the wiring connections to the heating element. Now, use a multimeter and check for the resistance reading (ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Dishwashers
Not drying. is there a safe way to test the heating element?
Hello there
Here is a detailed list of things to check to ensure that the element is your problem cause there could be a couple of different things also click on the blue items
If the dry cycle has a problem, check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Best regards mike
Apr 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
Electric oven not working on our elba excellance oven. Thermo has been replaced but oven worked for 1 day then went again. What is the problem please?
Jul 06, 2009 | Lux Elba OV 5085 LUX
Water isn't heating up and not drying
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
Mar 12, 2007 | Zanussi 18 in. ZSF4123 Slim-Line...
Dishwashers Logo
15 people viewed this question
Top Dishwashers Experts
