Question about Refrigerators
I need to locate the fan for a Haier fridge on top freezer on bottom
    Champion:
    Habit-Forming:
  • 275 Answers
You have to remove the shelves firstly, there is a panel at the back that containes the fan, it will have covered screws or the panel will just pull out, that will reveal the offending fan.
Posted on Nov 29, 2013
4 Suggested Answers
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
landsend
  • 1066 Answers
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
  • 12650 Answers
SOURCE: I have a Haier model HTE14WAAWW refrig. with top
check the fan in freezer sounds like it is stuck [iced up ] or needs to b lubed at the back of freezer will see fan feel if fan is blowing or just humming
Posted on Sep 24, 2009
Bottom freezer - Refrigerator top not cooling- All vents from freezer open , no food in the way. Is there a fan ?
Yes there is and it is located in the base panel of the fridge. Look for a set of slotted vents in the inside of the fridge and the fan is located behind those slots. This fan uses the freezer temp to control the fridge temp.
Good luck hope this helped you some
Dave
Jan 29, 2010 | Maytag MBR2256KES / MBL2256KES
I have a Haier model HTE14WAAWW refrig. with top freezer. The refridge humes loudly. The freezer works, but to lower unit does not get very cold. The fan at the bottom, for the compressor does work. Please...
Sep 24, 2009 | Haier Refrigerators
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Haier HRF10 what would happen to the fridge without condenser
it could but the possibility is low but you willl ruin the ref doing that
Jun 29, 2009 | Haier HRF10 Top Freezer Refrigerator
The freezer is cold but not the fridge?
fan motor from freezer to fridge out. What this motor does is allow freezer temp to be used to cool fridge. Motor is located between the bottom panel of the freezer and the top panel of the fridge.
Apr 16, 2009 | Kenmore 61042 Top Freezer Refrigerator
Haier fridge- freezer fine, fridge not getting cold. cooling fan for fridge not coming on
Apr 05, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Apr 02, 2008 | Haier HTQ21JAAWW Top Freezer Refrigerator
Haier model# HTQ21J*SS freezer ices up with melted water, not draining
Go to an electronics section of Walmart or Target, buy a can of "CleanSafe Dust Remover" compressed air in a can and try to blow the drain clear from the freezer portion. If that doeasn't work, let me know.
Mar 14, 2008 | Haier HTQ21JABWW Top Freezer Refrigerator
Leaking water INTO fridge
Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
Jan 21, 2008 | Haier HTQ18JABRSS Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
