Hec blu-ray comcast remote code
My hec blu-ray remote broke and i need the code to program it to my comcast remote
SOURCE: I need a remote code for Sylvania NB500SL9 Blu-Ray player
try 093. it worked on my samsung remote for my insignia blu ray player. Insignia instructs you to use sylvania codes and this code is listed under DVDplayers in my samsung guide. like i said...it worked for me!
Posted on Apr 29, 2009
SOURCE: LG Blu-Ray BD-370 unlock codes
http://www.multi-region.net/lg_5931
Posted on May 01, 2009
SOURCE: Universal Remote code for Insignia Blu-ray dvd player NS-2BRDVD
Insignia says it will not work with a universal remote there is no code.
Posted on Feb 02, 2010
supertech6
  • 513 Answers
SOURCE: Need the remote codes from a bdp s-550 to program another remote
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Posted on Mar 29, 2010
SOURCE: I need a code for Samsung BLU Ray Player for a universal remote
For my Vizio 3D 55 inch I used the code 119 on my Samsung Blu-ray HT-C6600
Posted on Feb 19, 2011
How do I reset anti theft on 2000 lincoln Continental
You take it to the dealer , you have no idea how it works ! Takes factory diagnostic tool to get into the system . No magical fix like disconnecting the battery . Need to find what codes are stored in the PATS control module .
The passive anti-theft system (PATS) uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user. This system is known as SecuriLockĀ® in North America, SafeguardĀ® in the U.K., and PATS in Continental Europe. This information can be found in customer literature such as the Owner's Manual.
PATS uses a specially encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code out of over 72 million billion combinations.
Each encoded ignition key must be programmed into a vehicle's hybrid electronic cluster (HEC) before it can be used to start the engine. There are special diagnostic service procedures outlined in the workshop manual that must be performed if the encoded ignition keys need to be replaced.
The encoded key is larger than a traditional ignition key. The key does not require batteries and should last the life of the vehicle.
The transceiver module communicates with the encoded ignition key. This module is located behind the steering column shroud, and contains an antenna connected to a small electronic module. During each vehicle start sequence, the transceiver module reads the encoded ignition key identification code and sends the data to the HEC.
The control functions are contained in the HEC. This module performs all of the PATS functions, such as receiving the identification code from the encoded ignition key and controlling engine enable. The HEC initiates the key interrogation sequence when the vehicle ignition switch is turned to RUN or START.
PATS uses the powertrain control module (PCM) to enable or disable the engine. The HEC communicates with PCM over the J1850 network in order to enable engine operation. The HEC and the PCM use sophisticated messages in order to prevent a theft. The HEC communicates with the lighting control module (LCM), which controls the theft indicator.The HEC and the PCM share security data when first installed together that makes them a matched pair. After this security data sharing, these modules will not function in other vehicles. The shared PCM ID is remembered even if the battery is disconnected. The HEC also stores the vehicle's key identification code even if the battery is disconnected. There are special diagnostic workshop procedures outlined in this service manual that may be performed if either the HEC or the PCM needs replacement.
All elements of PATS must be functional before the engine is allowed to start. If any of the components are not working properly, the vehicle will not start.
PATS uses a visual theft indicator. This indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS problem, this indictor will either flash rapidly or glow steadily (more than three seconds) when the ignition switch is turned to RUN or START. PATS also "blips" the theft indicator every two seconds at ignition OFF to act as a visual theft deterrent.
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood, and trunk) and sounds an alarm.
The PATS is not compatible with aftermarket remote start systems, which allow the vehicle to be started from outside the vehicle. These systems may reduce the vehicle security level, and also may cause no-start issues. Remote Start systems must be removed before investigation of PATS-related No Start issues.
May 20, 2016 | Lincoln Cars & Trucks
I'm trying to program a Comcast cable remote silver with red ok button to operate my Sony BDP-S3200 Blu-ray/DVD player and need the code please.
This is a Comcast baby - U are paying them plenty for the service - they should help you with the remote. Don't let them off the hook.
Nov 07, 2015 | Sony Televison & Video
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
I need code for hec dvd player mod# 110
Remote codes, if any, ae gotten form the manufacturer of the remote.
Dec 08, 2013 | Universal Remote Control DIRECTV Universal...
Code to unlock region on HEC PDVD790 (Haier) Portable DVD Player
I really doubt that you can't unlock the region on your device.
The manufacturers have it locked for a reason.
Dec 25, 2011 | Televison & Video
2000 ford f150 change computer from junk yard , well not start now ,but showing theft light ,do I have to get this thing flashed
The HEC ( hybird Electronic Cluster ) has a PCM ID stored in it, that needs to be cleared from the old one you had, so the new one can be re-learned.
The HEC sends the valid key tag with the PCM_ID configured in the HEC to the PCM for comparison to know if the start enable should be valid or invalid
This is so someone cannot take a cluster, ignition key cylinder and the PATS keys configured in the HEC, and put it into a truck, to make it start. Takes a bit of programming to get it to work.
Going to need someone to erase the PCM_ID parameter in the HEC to make the truck not think it is being stolen ( good news, it works as advertised ).
Feb 05, 2011 | 2000 Ford F150 Flareside SuperCab
98 lincoln town car wont start, the theft protection is activated
theft protection rsets itself. I have never seen a PCM go bad. Some just need a reflash which costs much, much less. You can get a used PCM if you really think you need one, at car-part.com. Page with asterisk is lowest price.
here's some info on antitheft. What's your red light doing on the dash when you turn on the key or try to start the car?
The passive anti-theft system (PATS) also contains the following components:
  • Theft indicator.
  • Encoded ignition key.
  • Passive anti-theft transceiver module.
  • Hybrid electronic cluster (HEC).
  • Powertrain control module.
  • J1850 communication network.
  • Lighting control module (LCM).
The passive anti-theft system (PATS) uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user. This system is known as SecuriLock® in North America, Safeguard® in the U.K., and PATS in Continental Europe. This information can be found in customer literature such as the Owner's Manual.
Jun 05, 2009 | 1996 Lincoln Town Car
Need physical dimensions of HEC HP585D 585W ORION HP585D ATX
No, given your old PSU's dimensions the HEC PSU would be too large. It sounds like you have a micro-ATX case.
Apr 06, 2009 | HP HEC HP585D 585W ORION HP585D ATX 12V...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
