Question about Sewing Machines
Jcpenney sewing machine 7057
The feed foot on my machine has stopped moving. It is not feeding the material through. Can I easily fix this myself?
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
  • 152 Answers
SOURCE: The feed dog is not grabbing the material or the
The little white button on the lower right front of the machine is the button that drops the feed teeth. If it is pressed in the feed teeth are down, push in a lift upward to be sure it's in the "Up" position. Then look on the left side of the machine, you'll see a dial, (NOT the dial facing you as you sit in front of the machine) make sure the red dot on the dial is lined up with the red dot on the painted part of the machine.
Finally look at the dial on the front of the machine. The one with the little button in the center of it. Put it on the number 3. If your machine doesn't feed fabric after doing what I've outlined then you need to take it in for service.
Posted on Oct 23, 2009
Zenqi
  • 208 Answers
SOURCE: started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Posted on Nov 14, 2009
  • 96 Answers
SOURCE: Sears Kenmore Sewing machine model wont feed
you need repair service for that one
Posted on Dec 13, 2009
WonderTech
  • 268 Answers
SOURCE: Machine does not feed properly. It sewed fine for
Here are a few solutions to check.
* Check your fabric to make sure it isn't caught on something.
* Check your pressure foot to make sure it's screwed tightly in place.
* Adjust the pressure of your pressure foot as it may be too light or too heavy for your fabric.
* Check your feed dogs for lint. If your feed dogs are clogged with lint, they're not gripping your fabric properly. Remove your pressure foot and clean out any lint with an old toothbrush.
* Raise your feed dogs if your machine has this function. They may have been inadvertently lowered.
* Check your stitch length regulator, If its set at “0” or a very small number, try switching to a longer stitch length.
* Change your needle, it may be damaged.
* Check your needle plate and make sure it's securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you've been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
Posted on Mar 23, 2010
Pressure foot wont go fully down
The pressure foot is only made to push down on the material, not the feed dogs. If you put it too low it will destroy the feed dogs and the pressure foot as well as the material.
1. To adjust, lower the pressure of the pressure foot as much as you can.
2. Place a thick piece of material under the foot. Turn the hand wheel until the feed dogs are up.
3. The pressure foot rod has a screw that holds it into place. You will adjust the rod by moving it up and down until there is a small amount of pressure on the material. Tighten the screw and try your machine without a needle to see if the material will move. Now, try other thicknesses of material. The rod may need to be slightly adjusted a small amount to get it "just right".
4. PUT IN NEEDLE AND CHECK FOR ALIGNMENT TO THE HOLE. (DANGER IF NOT ALIGNED).
Aug 22, 2016 | Bernina Activa 130
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
When i start to sew my presser foot is not moving at all and all thread i think accumulate at the back of cloth .. please help
The presser foot should only glide over the material. The feed dogs move the material. Check to see if your machine has a drop feed feature... for embroidery... or darning, etc. If it does return the feeds to sewing position.
Sep 24, 2013 | Sewing Machines
Does 514 pressure foot move?
what is the name of the machine?
do you want a manual?
the feed dogs are what move the fabric thru the machine, the presser foot only hold the fabric against the feed dogs so the feed dogs can move the fabric
the feed dogs in the needle plate area should be up
May 28, 2012 | Sewing Machines
I have a Finesse sewing machine and I was sewing some placemats but it suddenly stopped feeding the material although it keeps sewing (foot moves up and down). According to the book I have checked the...
Can you see the feed dogs moving?
un thread, raise the pressure foot then manually turn the flywheel towards you and watch the feed dogs (the teeth that move under the needle plate). If they are not moving around and coming up above the needle plate then one of two things:
either you've accidentially disengaged the feed dogs, check the manual for instructions to reengage, sometimes a knob, button or slide, often on the front base or around the back of the free arm.
If they are engaged but not moving up at all, then something has gone in the drive to them, usually a gear in the free arm area. In which case, take to the shop for repair.
Jul 01, 2011 | Sewing Machines
Will not feed the material through
Be certain the presser foot lifter handle is down so that it holds the fabric from the top. Then make sure the feed dogs (the little toothy looking things under the presser foot) are up or engaged. Often we'll accidentally knock the adjustment button/lever and the feed dogs go down into the machine and will not come up to provide the pulling action to feed the fabric through. Make sure the mechanics inside the machine are clean and free of dust. And if you see what seems to be a piece of felt around the feed dogs, that is actually lint and prevents the fabric from moving through easily. Use the brush that came with the machine to clean the feed dogs. Hope this helps and happy stitching!
Oct 28, 2010 | Necchi 3537 Mechanical Sewing Machine
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
I have a Singer 401 A sewing machine. Nylon material will not move across the foot plate when I am sewing. The tension of the foot seems good. It was working then all of a sudden it stopped moving. I...
By saying the tension of the foot is good I take it you mean the pressure is set good. Maybe add more pressure. Are you sure that the lever on the bottom right is set for sewing and not darning which raises the needle plate above the feeddogs? Sure that your feed dogs are moving well at the stitch length set. With slippery fabrics you may need to try a different type of foot. There are some plastic or teflon coated ones that will not stick to or hold the material back. Or try a Walking Foot or Even Feed foot which will move the top of the fabric evenly with the bottom.
They do help alot.
Good luck
Apr 22, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
