Question about Fellowes Saturn 2 A3 Laminator Laminators
Laminator wont feed - Fellowes Saturn 2 A3 Laminator Laminators
  • 52 Answers
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Posted on Nov 26, 2013
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
Feb 05, 2017 | Fellowes Office Equipment & Supplies
Why is my GBC Ultima laminator beeping?
It will beep when you turn it on to acknowledge power. It will also beep when it reaches ready condition. Your laminator has safety switches for the lower feed tray and upper heat shield. Any time the upper shield is lifted the power is shut off. When you lower it down the power is turned back on, causing a beep. The same is true for the lower feed table. When it is removed and then re installed the machine beeps. These are safety features so that the laminator doesn't turn on when you are reloading it or unjamming it. Check that the safety switches are fully engaged if you get unnecessary beeping.
Oct 25, 2016 | Gbc Office Equipment & Supplies
My laminator (Enduralam 60") wont operate. there is obvious power as the off switch glows orange. I push the go button and nothing happens
Have you read the manual? You can find a manual for make and model by Google, and you should get it in a .pdf format. Are you also using the right cover card to feed into the slot?
Nov 20, 2014 | Office Equipment & Supplies
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
I have a xerox laminator and it will not feed
Unplug the machine. Then try to look, using a flashlight, if there are any obstacles that may interfere with the feeding. try to gently tilt the machine and try to remove any obstructions. If you can't see anything, try to force something through the feeding path and see if something is stuck in there.
If this doesn't work, them you might want to take it apart.
Nov 16, 2012 | Xerox Staples XRX-LM1910 Laminating...
How doses the plastic feed through the xrx lm1910 laminator
You will need to make sure that you are using the right type of plastic. also, is the plastic the right size? Also, you need to check if you are trying to feed at all. Are you able to feed the paper?
Jun 08, 2012 | Xerox Staples XRX-LM1910 Laminating...
The unit was heated up and when I insert the laminator pouch with the document to be laminated it does not feed. it just cooks the front edge of the pouch. do I need to let the unit cool and start...
Hi, there's a seperate switch for the moter on my laminator. After the device is heated up you need to turn on the switch, so the mechanism starts to pull in the pouch.
Mar 14, 2011 | Xerox Staples XRX LM1910 Laminator
I have a Lamiart-3201 laminator and the rollers are not working - or i cannot feed my item through the laminator. Usually I just put it in and the laminator feeds it out the other end...
Make sure your laminator is heated up properly before feeding material through. Usually, for a low-end laminator, you will wait anywhere between 10 to 20 minutes before it is completely heated up, allowing you to use it. There should be a red button that will tell you it is NOT ready yet, and a green button will tell you it is.
Nov 16, 2010 | Office Equipment & Supplies
GBC Eagle 35 Laminator heats up, won't turn
I have seen issues with the safety switches on the clear front cover (both sides) not getting pressed even though cover is shut, also there are switches under the feed table so it has to be set correctly (pins) let me know if this helps
Oct 24, 2007 | Office Equipment & Supplies
Fellowes Saturn 2 A3 Laminator Laminators Logo
547 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
