Question about Gateway MD2614u Notebook
Gateway laptop md2614u is running ok now
Hi i think i solve the problem on my laptop is keep on shutting down. i bought some thermal paste and took the fan and heatsink out and clean it up and put some around it. and now i boot it up and won't crashed any more and now i'm doing windows updating right now and still running. why does pc vs laptop temperature is different 1. pc motherboard 35 c laptop is 83 c,2. pc 29 degrees c laptop 78 degrees celc. 3. i have 2 fans running than laptop and that always gets hot easily,.
  • 41 Answers
30-50C is normal idle temp, 50-100C when running stuff but anything over 70C is getting a little too hot if you ask me but i\'m not an expert on that one. The only thing you can do is make sure you have cleared out as much dust as you can from the inlet and outlet vents on the PC, make sure they are free to suck air and blow air, clean the fan blades, if still having probs thing about getting a better fan. The common mistake people have with laptops is using them on a bed or cushion which is a big NO no as this will block vents and end up burning out the PC, will overheat. Always use on flat surface. PC\'s have much more airflow so temp will be generally lower than a laptop as laptops are very compact not ideal for ventilation.
Posted on Nov 23, 2013
2 Suggested Answers
jonsnell4
  • 21561 Answers
SOURCE: gateway md2614u shut down
I would remove the heatsink and fan, clean the processor surfaces with methylated spirit or isopropanol, use new heatsink compound and that should fix your issue. Yes yes, heatsink pipe should get hot!
Posted on Nov 17, 2013
Gateway intermittent shutdown
I installed a new alternater th battery is new
Dec 27, 2013 | Gateway MD2614u Notebook
Gateway md2614u shut down
Nov 17, 2013 | Gateway MD2614u Notebook
Laptop shut down
Sounds like it is getting too hot. Does it feel real hot when it shuts down? Is the fan and power supply working well and unobstructed so they get good air circulation?
Gateway md2614u shutting off
It does the same on AC and Battery? Open the Control Panel, select Power Options, select High performance, set Plugged in, both to Never, Open Advanced Power settings, set Sleep and Hibernate to Never. Use this procedure: http://msdn.microsoft.com/en-us/library/ms700612(v=vs.85).aspx ALSO, right click a open spot on the desktop and select Personalize, set Screen Saver time.
Feb 27, 2013 | Gateway MD2614u Notebook
My driver for my webcam is gone for my gateway laptop MD2614u
You can reinstall the WebCam Drivers from the recovery manager, to do so:
Click Start> All Programs> Gateway> Restore> Reinstall Application and Drivers> Select the WebCam drive and install it
OR
Visit Http:\\support.gateway.com to download the drivers.
Regards,
Anil.B.R
Sep 07, 2010 | Gateway MD2614u Notebook
My MD2614u I believe overheated. It had been in use all day while sitting on a wooden desk. The computer was shut down by putting it in sleep mode. A short time later we tried to reboot and all of the...
I suggest you wait at least 1 hr before trying to restart it. Leave the laptop off during this time. This will give enough time to the CPU and other components to cool down.
Mar 23, 2010 | Gateway MD2614u Notebook
I have a ML6230 Gateway and it keeps shutting down after a few minutes. Doesn't matter if it is running on the battery or AC. Changed power settings so it is not hibernating and the fan is running but...
Computer shutting off after a few seconds to a few minutes
This sounds like an auto shut-off signal given by the processor because of a possible over-heating issue. This usually happens when the laptop has been run for an extended time without having the dust, dirt and debris cleaned from its cooling vents and grills. After time, the thermal paste on the processor bakes under the extreme heat and starts to flake off and lose its efficiency at cooling the processor.
Get a few cans of compressed air that you would buy at an office supply store and using short bursts, blow out the dust and dirt from all the ventilation grills and vents first, make sure the laptop is powered down and battery removed. Then, open all the compartments and clean them out as well including the cd/dvd tray. There is a small black hole on the dvd bezel, just stick an open paperclip in it and it will pop the tray open. Blow a good blast in there to clean the dvd player.
There is the possibility that the thermal paste will have to be replaced, that means you need to gain access to the heatsink and remove from the processor, clean all the old thermal paste from it and apply a small thin layer of new paste to the top of the processor and replace the heatsink, securing it evenly with the attached screws.
Oct 10, 2009 | Gateway ML6230 Notebook
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
Gateway MD2614u Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
