Question about Kitchen Ranges
Lg washing machine error code d6 - Kitchen Ranges
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
taran_2005
  • 10515 Answers
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Posted on Jun 17, 2009
  • 111 Answers
SOURCE: error code se
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Posted on Jun 18, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
Posted on Feb 16, 2010
LG washing machine error codes I got TCL error code on LG my washing machine What does it mean?
that means you need to clean the tub. use your search engine on the net to learn how. then the error code should go off.
Jul 26, 2017 | LG Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Lg front load wm conversation moto type le error pls
    Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
    LG Washing Machine Error Code = LE
    LG Washer Error = Drive Motor Locked Error
    CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
    LG Washing Machine Error Codes Washer Fault Codes
    Apr 03, 2016 | LG Washing Machines
    LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
    go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
    Aug 29, 2015 | LG Washing Machines
    Washing machine LG TR9103AEP IE error what does it mean ?
    LG Top Load Washer-Understanding Error Codes - YouTube
    ? 2:17
    www.youtube.com/watch?v=ZdoJVqFKye4
    Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
    Aug 04, 2015 | LG Washing Machines
    What does error code 000000 -0000 means
    How do you reset the error codes for an LG washer? - ImFee
    www.imfee.com/how-do-you-reset-the-error-codes-for-an-lg-washer.html
    Reset error codes on an LG washing machine by unplugging the machine, pressing ...locked 3G phones can be unlocked with the codes "123456" or "000000.
    Jul 28, 2015 | Washing Machines
    We are getting an LE error on a LG WT R852 washing machine
    Here is a tip that explains what the LE error code means.....
    LG Washing Machine LE Error Code or Fault Code
    heatman101
    Aug 13, 2011 | Washing Machines
    LG washing machine loud and error code LE
    heatman101
    Jul 02, 2011 | LG WM2301HW Front Load Washer
    Kitchen Ranges Logo
    19 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
