Question about Refrigerators
GE TFX20JR manual, where can I find 1? - Refrigerators
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Try google "user guide model #"
Posted on Nov 23, 2013
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
GE 19.7 TFX20JR not cooling or freezing
I think you fridge is low an gas, refill it
Mar 14, 2013 | GE Refrigerators
I have a GE Side-By-Side Refrigerator Model # TFX20JR . The refrigerator handle is loose and needs tightened and I can't find anything in my manual telling me how to do it. Your help would be greatly...
you must remove the inner panel to get to the handle screws on most ge 's . use red lock tight on threads to prevent it from doing it again . mm
Aug 09, 2010 | GE Refrigerators
GE TFX20JR
how is the freezer? if it is ok is the freezer back panel full of frost if so then you have a defrost problem and the ge is really good for the heating elements to go bad
Jun 26, 2009 | GE GSH22JFR Side by Side Refrigerator
Not cooling properly GE TFX20JR i tried the defrost timer and it is working, now what other possibly problems could there be? thanks!
Do you have ice /frost buildup on freezer wall?If so auto defrost is not working.3 possible causes ,turn the defrost timer manually to defrost position either measure amps @ 3.5 amps or listen in freezer section for crackling popping or sizzling.If you dont hear/measure this you have a bad heater or defrost tstat .Remove freezer wall look at top of coil for thermodisc 2 wires and 1 or 2 glass heaters (btm,mid coil).Tsat can be bypassed by connecting the 2 wires or checked for continuity closed at approx 20'.heaters may be visibly burnt or broken recommend changing both parts
Jun 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Nov 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
