Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Display panel The timer display on my Hotpoint WD640 washing machine displays 0.02 minutes of a cycle remaining. I have turned the dial in an attempt to re-set the timer but it still shows 0.02 mins. I have let the cycle run, it then displays "end" and reverts back to 0.02mins. I have switched the machine off at the plug, but this has not helped. The previous wash and dry ran fully and was not stopped with two minutes remaining so am unsure where this has come from. Please help!!
  • harleyhocks Oct 10, 2007
    The last time the washing machine worked succesfully, it was on a drying programme so there are definitely no water or suds left in the machine. We have cleaned the filter but it has made no difference. I cannot use any wash/dry programme as it does not seem to recognise the programme selected and continues to show 2 mins remaining... Any more suggestions?? Many thanks
    Problem Solver:
  • 15 Answers
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Posted on Oct 10, 2007
  • James Crawford Oct 11, 2007
    see if you can gain access to the bottom some machines have a service manual inside the machine to help aide the tech. and may have codes the 02 may be a code that tells the tech. what is wrong. Sorry i do not have a lookup for your machine .also you may want to call the manufacter the to may have a tech. line
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Wd640 hotpoint washer dryer the time display is
It can be the timer processor is fault and is not accepting any other program than one that is set into. remove plug and remove control board , clean and reset with tight connections, check the processor section, solder the IC and associated sections, now set back and set the clock and try once again after cancelling - pressing stop for few seconds.
If the fault stays it is problems in the timer control PCB,but it might change with prolonged resetting ,if there was dirt inthe PCB.
Sep 25, 2010 | Hotpoint Washing Machines
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint qasher/dryer aquarinus super silent wd640 1400 spin just says test on displays and does not let me wash :(
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} According to the manual ‘TEST’ should only appear in the display when the hardware key is inserted into the rear socket of the machine ready to commence a test sequence. The only advice I can give is to turn the appliance off and remove the plug from the power socket for at least one minute then plug it back in and try it again. These machines have 3 phase motors and the heat sink on the module retains an electric charge for some time after the appliance has been switched off so be mindful if you decide to venture into the inside of the cabinet.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault f13
Hi. F13 indicates dryer fan motor or thermistor problem
If you can't hear the fan motor running on the dry cycle then it is probably faulty.
Hope this helps.
Please feedback.
Thanks
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
INTERMITANT FAULT
This is a plumbing error and not a machine error. H20 means "water turned off or valve faulty"
Jul 02, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Washer Dryer
I had a similar experience.  I had to try a few times - it has to be EXACTLY together and then the magic "doff" shall appear and save the world.
Dec 19, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF640
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
195 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
