Question about Refrigerators
GE side by side fridge TFX20JR. Got the ice maker set up & a filter on the hose going to the fridge. After about 2 months the water started having a really bad smell & started Fizzing almost like waterdown soda. What is causing that & how can I fix it? Can't make ice or drink the water it's smells so bad. Help please!!
    New Friend:
  • 20 Answers
Try changing the filter and discard all the old ice.
Posted on Nov 23, 2013
  • Wylane Justus
    Wylane Justus Nov 25, 2013
    I've done that many times. I'm not sure if my fridge has a filter on it. I've been trying to get a manual for it but u keep getting the runaround from sites. I know it's not anything in the fridge or the freezer. I've cleaned the ice holder out many times. It has to be sumthing in the hoses or in the reservoir, but I can't even find where it is on my fridge(no manual). Was told if I could clean it out it mite help, or I mite hafta buy a new 1. If my fridge has a built in filter, I have no clue. I put 1 on the hose from under the sink to the fridge & both were brand new. Filter had a 3yr warranty & it didn't ever get to be used 3 months b4 this started happening. Wondering if any1 can help find a manual(with pics) so I can find the things easier. It's a GE TFX20JR & that's the only numbers on it. Sidebyside. I would be very great full!!
2 Suggested Answers
jvernice
  • 63 Answers
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Posted on Jul 29, 2009
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
I have a ge tfx20jr side by side the ice maker is not dumping the water fills the tray but it won't dump
That is an electronic control ice maker and possibly worked hard for the last few years. If the ice maker will not respond to the full arm or switch being on to empty the cubes about the only thing you can do is replace it=> WR30X0327 Ice Maker Assembly
I am here if you have questions, John Tripp Appliance 911
Contact me here.
Jul 30, 2014 | Refrigerators
After replacing the cartridge, the water flow is extremely poor. After calling GE, I was told I may have a bad filter. Hope not at the price per filter they charge. Is there any other solution? Is it...
The GE GXRLQR is the correct *replacement* filter for the following "Smartwater" single stage filtration and exterior refrigerator icemaker systems:
  • GE GXRLQ
  • GE GX1S50F
  • GE GQ1S50F
This filter is rated for only 750 gallons / 6 months of use (typical fridge with ice maker & water service). Most home faucets will deliver about 6 gallons / minute which roughly translates to about 2 hours of running water.
The GE FQSLF works with the following for the following Dual Stage Under Sink filtration systems:
  • GE GQSL55F
  • GE GXSL55F
Because there are 2 filters, they will last nearly 2x as long as the GE GXRLQR. and would likely be better suited to serving a faucet which will pass much more water than a fridge ice maker & chilled water dispenser would.
The real question is: Which GE filtration SYSTEM (not filters) do you have?
Sep 09, 2013 | GE GXRLQR GE SmartWater Inline Filter...
ICE MAKER QUIT WORKING ON GE 19.7 TFX20JR BUT WATER STILLS WORKS
you have a dual valve one side quit working. get a new inlet valve.
Aug 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Ice maker tray not filling with water.
Changed the filter, now it works fine. I'd still like to find a way to bypass the filter. My fridge is only 2 yrs. old, but I'm sure it will have plenty of life left after these filters become unavailable.
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR Have ice but no water
you have a duel water supply valve on the back bottom of frig.,the water dispenser side might be bad,or you have a micro switch behind the water dispenser that could be bad,check both-mike
Nov 20, 2008 | Refrigerators
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
