Question about BellSouth Radio Communications
One unit charges, but the other doesn't.
The charge light shines brightly for one, but only comes on with the other if the unit is turned on. However, though the light is on, it doesn't charge.
    Problem Solver:
  • 16 Answers
Does this happen when you switch the radios in the chargers. are the terminals on the charger clean, no corrosion. change the batteries form 1 radio to the other does the same thing happen, then it must be the battery going
Posted on Nov 28, 2013
2 Suggested Answers
  • 45112 Answers
SOURCE: 22 channel two-way......one unit charges, the other does not. The charge light comes on for each unit, but quickly fades out on the one that doesn't charge. The working unit charges in both sides.
Try replacing batteries in the defective one.
Posted on Nov 23, 2013
My casio calculator has been discharge so I put it in sunlight then it starting working but as I come inside the room it stopped. please tell me what to do
Shine a bright light on the calculator while indoors to charge up the internal battery. The solar cells don't need sunlight....just light to work.
Jun 17, 2017 | Casio Office Equipment & Supplies
Cant get my starter to engage when I turn the key on.
Is the battery fully charged and all cables clean and tight? You can try tapping on starter motor with a blunt object while trying to crank it. If it starts, the starter motor is bad
May 10, 2015 | 2002 Pontiac Bonneville
My monitor dont work anymore but when i charge it ..the charge light light up...and when it fully charge it turn green but still dont come on.. no water in or i didnt drop it help me
probably back light is out. Look closely at screen and see if you can see a faint image on screen (hard to see if no light behind to shine though, so look close).
May 21, 2014 | Uniden UDR444 - Monitor Lcd 4.3 Tchsc Bk
Battery/elecrtic
You might unhook the battery and with the camper plugged in to shore power the 12v lights should work. If not check the breaker that goes to the inverter. If that is not tripped then check the power output at the converter. I would expect the inverter is shot. I replaced the one on my Jaco two years ago with (Progressive Dynamics 60 Amp Power Converter with Charge Wizard and the remote pendant)
Apr 02, 2014 | Jayco 2010 Jay Feather SPORT 165
Battery on lg shine not charging and not showing how much battery life is left
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 02, 2012 | LG Shine KE970 Cellular Phone
When you try to start the car it just clicks, if you turn the headlights when the cars not running the dashboard lights start to flicker.
Sounds like a very low battery to me. You need to have your battery and charging sytem checked.
Dec 29, 2011 | Cars & Trucks
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
I have a 460 eng. that the b attery is brand new but the solinoid just buzzes when trying to start. what is the problem
Usually, this is caused by a discharged battery, corroded battery connectors, or cables. Turn the lights on--do they shine brightly? Now try the starter with the lights on--do the lights dim out? Have someone check the battery voltage at the posts while trying the starter. The battery should remain near 12.6 volts or a little less. If it drops to a low reading, charge the battery with low current charger for about 8 hours. Less time with higher current charging. Hope this helps!
Oct 02, 2010 | 1982 Ford F 250
Problem: While charging, the front screen light is on and bright when charging the phone. It stays lit while the plug is in. Does anyone know of a way to turn this off? Thanks much!
Hi, no im afraid their is no way of doing this the light is on just to remind you the phone is charging, i know it can be annoying but their is nothing you can do to turn it off, all you can do is turn the phone over so the light isnt shining all the time.
they do it so you remember to take it off charge when its fully charged, i know its annoying but their is no settings you can change to get this light turned off, i have loads of people asking me the same as you but their is just nothing at all you can do to change this
so im sorry i cant give you an easy fix but its just not possible to have this light turned off, annoying yes i know, but its something you have to put up with,
sorry
Aug 30, 2010 | Samsung Convoy Cell Phone
Vectorlite 1.5 candlepower shines a dim light instead of a bright white light.
Either the battery is not fully charged or it is time to replace it. Try charging the battery. If that doesn't work you will need to dissemble the light to obtain the replacement battery numbers. It should take (2) Model CA645 Batteries. They are 6 volt 4.5 amp hr.
Jul 16, 2010 | Camping, Backpacking & Hiking
Radio Communications Logo
54 people viewed this question
Top BellSouth Radio Communications Experts
Steve
ka4iup
ka4iup
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
