My Verbatim #BC1TB hard drive seems to have died. It won't turn on.
I noticed it had not backed up for 10 days, and when I try turning on the power, it does not respond. I tried plugging it into a different outlet, but still nor response. How do I get my data off it, and is it recoverable?
  • 3 Answers
If this is a desktop, remove the side panel and blow it out using a shop vac in the blow mode. Blow out the dust and cobwebs. Worth a try. Jack
Posted on Nov 23, 2013
4 Suggested Answers
  • 624 Answers
SOURCE: printer suddenly dead
It's possible the power supply died, however, there is a 3amp fuse on the slide in power unit that could have blown. I would check it before taking it to the recycling pile. If you mess with it be careful around capacitors, they'll hold a charge even if not connect to power for several days.
Posted on Nov 26, 2006
freetek
  • 5568 Answers
SOURCE: My pixma ip3000 wont turn on
This sounds suspiciously like a problem chronic to a certain type of power supply called a 'switcher' that uses a technique that employs high frequencies in the power conversion process and is caused almost always by the use of cheap capacitors in the path of high frequencies. The value of the capacitor shrinks from decay of the electrolytic solution used in these parts.
Currently, there are millions of these parts in circulation with a defective solution (poorly made in China) used in their manufacture causing failures in many different electronic devices.
The typical symptom is either a failure to turn on when powered up or simply stopping.
It is a problem that was endemic in certain fax machines in the 90s and since they were more expensive then, it made sense to remove the supply and repair them.
Quite frankly, this weakness earned me thousands of dollars as a sideline and once I had established the failure mode, I added a 50 cent part then could guarantee the repair for the 'life of the machine' and never had a single return out of many hundreds of repairs.
Unfortunately for owners, is the need for a capacitance meter to locate the faulty part and they cost more than a replacement printer.
If anyone has the instrument, the technical skills, and wishes to 'try this at home,' email me and I will detail what to look for.
freetek@lycos.com
Posted on Jun 10, 2008
  • 3278 Answers
SOURCE: Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
Posted on Jul 16, 2009
My model BC1TB has not backed up for 10 days, and does not turn on when plugged into AC power. It it dead?
It may not be your hard drive but the enclosure casing that is not powering up your drive. If you are a self do'er, open the enclosure and take the hard drive out. The hard drive should be a SATA. Do only this if the warranty has expired otherwise you will void the warranty. You can purchase another enclosure for your SATA drive. To test if the hard drive is still operable, you will need to open the case and connect the hard drive to a SATA controller via a data cable/15 pin power connector. If you're a novice, I recommend getting a hard drive docking station which will connect via usb to your computer/laptop.
Nov 23, 2013 | Computers & Internet
My hard drive does not seem to turn on! i.e.-- no light on, not showing up in Finder (I have an Imac) I've changed ports, and outlets... no luck.
either the case power connect died or the whole unit went bad.
you can try pull out the hard drive and put it in another external usb case to see if it will work.
Mar 06, 2011 | Verbatim (96759) 1 TB USB Hard Drive
My pc wount boot if i turn on my verbatim 1 tb before i turn on my pc, it stops booting on the blue intel 4 screen
The way to stop this is to turn off usb boot support in the bios. Essentially its trying to boot from that hard drive, enter the bios and look for usb boot and disable it.
Jan 07, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
Took RAM out. Put RAM back in. Removed hard drive. Reconnected hard drive. Connected a second hard drive as a slave. When I plugged it back in I noticed a small red LED (PLED) beside the 5th card slot had...
Single long beep - the RAM is no longer recognized as present. Try the ram stick in another pc, if it works there then the motherboard has died, you will have to replace it.
Oct 20, 2010 | DFI CA64-EN Motherboard
Dear Sir I just bought a verbatim 500 GB external
When you press the button it takes a few seconds for the indicator light to come on because the drive is initializing on startup, in other words its starting to spin up which could take a few seconds. Press the button one time and wait 30 seconds to see if its just the delay for the Hard drive to come to speed. And the same for the shutdown it may take a few seconds for it to park the drive and shutdown.
If this helped give a thumbs up.
"Patience is a virtue" I read that somewhere.
Aug 17, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim hard drive wont turn on
I have the same problem with my verbatim 1 TB HDD, the only one difference is that i accidentally ejected the USB cable from the hard drive (not from the laptop) and after that the connection was lost of course and the small green light on the front side of the hdd was out. i reconnected the hdd but it never turned on again. the same thing happened to my samsung hdd around a year ago. i will never no more trust in these things they're a kind of ****. (a have notice that i avsolutely took care of both hdd)
Oct 07, 2009 | Verbatim VER95327 USB Hard Drive
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
Usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Jun 08, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim 4gb flash drive settings causes error
Factory reset the unit. Hole on the back. Insert paper clip and hold for 10 seconds
Oct 02, 2017 | Verbatim CORPORATION 94933 USB 2.1GB...
163 people viewed this question
k24674
jasbo
jasbo
