Question about Sony KDF-E42A10 42 in. LCD Television
Input source won't change
Input source indicator changes, but the source itself is same
  • Bruce
    Bruce Nov 25, 2013
    Clicking through different input sources changes the inidicated source(cable, dvd, apple TV, et.), but the actual content diplayed alsways stays the same(in my case, cable)
2 Suggested Answers
Samtech
  • 16 Answers
SOURCE: Sony KV-24FV300 changing video input by itself - possessed?
It sounds like the tact switches (on the control panel) are defective.....This usually happens after some one cleans the screen with a spray and it drips onto the board, Or they went bad on their own.
Posted on Dec 21, 2007
Source changes by itself when watching tv.
Check your buttons on the TV . Sounds like input or source button ( which ever one they call it ) is pushed in & stuck . Only way to make sure would be to disconnect it & see if it still changes inputs .
Jan 12, 2015 | Samsung 46 UN46C7000 3D TV
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
No appearance if i switches on the t.v
does the power indicator light com on? Try switching the inputs with your remote. If you are hooked up to HDMI 1 ,for example, the tv input source needs to be changed. If you are coming from cable input, then the tv will need to be switched to the cable source.
Jul 09, 2011 | Televison & Video
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Apr 28, 2009 | Philips 19PR19 19" TV
Manual donwload
Video input source is changed by the buttons:
1. Video Source
2. Input
3. TV/Video
4. Source
one of those four on the remote some where.
Also, chances are your TV itself will have one of those buttons somewhere.
Usually pressing it will either cycle through the inputs or bring up a selection of them, which is usually navigated by either arrow buttons on your remote or the channel up and down keys.
Lemme know how it goes.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
DIstorted picture for 480p input only
Many set have two differant convergance settings one for 480 and one for1080 this is because when it changes mode the set runns a differant frequencys, what may have happened is you have a cold solder joint somewhere that takes this fifteen minutes to corect itself, might want to start by resoldering the convergance and high voltage curcuits
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
Dec 20, 2007 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Sound 'changes' when using different input sources
try to check the auidio setting on the dvd itself. make sure it is set to 6.1. I think it is set for 2.1..change the setting and you will be just fine. good luck
Jan 02, 2007 | Pioneer HTP-2500 System
Sony KDF-E42A10 42 in. LCD Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
