Question about Vizio VW37L 37 in. LCD HDTV
Only lines on upper part of the my screen
I only get some lines in the upper part of my screen and after a minute, the lower part is white. This was after a move to another state, TV was in the original box and in storage for about 7-8 weeks This problem is present on all inputs. It reminds me of older TVs that the vertical/horizontal hold is totally out of adjustment
    New Friend:
    Problem Solver:
  • 6 Answers
With the limited information on your issue and no voltage checks from within the TV, the best I can do is suggest the following.
sounds like a Ysus board issue and/or Zbuffer issue.
If it's the Zbuffer, change the Ysus card along with it as it could be the reason why you are having buffer problems.
While a buffer problem alone will not affect the Ysus card, a Ysus card issue will continue to blow Zbuffers if that's all you change.
check to see if it's still under an extended warranty, if not, then find the service manual for your model online and see if this is something you want to DIY.
Posted on Nov 23, 2013
4 Suggested Answers
  • 54 Answers
SOURCE: VIZIO GV4VL cuts off the bottom of screen
on the tv's remote you have a button which says one of a couple things. 1) pic size 2) ratio 3) zoom 4) aspect. using that button push it a couple of times until you get to either 16x9 or full depending on the brand of tv you have
Posted on Jan 22, 2009
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
dsacco86
  • 1077 Answers
SOURCE: We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Posted on Jun 13, 2009
Can't bring into focus the entire image. Corners defocused and have green/purple halos.
If it is a known problem, then it is a manufacturing error. They have just admitted that is a MISPLACED washer. Have Optima repair it free of charge.
Mar 28, 2017 | Optoma Office Equipment & Supplies
Green tint in picture
Are the lines completely through the screen or just the upper or lower part of the screen? If through the whole picture, lines in the picture of a plasma can be caused by a defective Main Logic Control board or a bad plasma panel. The panel, if available would be very expensive (cheaper to buy a new TV). If the lines are just on the upper or lower part of the screen then it is the upper or lower scan drive board. Here is a list of the parts for your TV.
https://www.tristatemodule.com/t-Search.aspx?q=TH-42PX60U
Nov 04, 2013 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Icons on the home page
Tap the white-on-blue up-arrow near the lower-left corer of the screen, then drag the unwanted icons to the icon bar at the bottom of the screen. When done, tap the white-on-blue down-arrow at the upper-left corner.
Bear in mind that not all icons can be removed from the home screen.
Aug 26, 2012 | Lg800g With 1200 Minutes And TripMinutes...
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
There is a white strip in the screen, how we can fix it?
horizontal line can fix need replaced Y BUFFER LOWER OR Y BUFFER UPPER BOARD
vertical line panel problem unworthy fix
Nov 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Vizio VW37L 37 in. LCD HDTV Logo
109 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
