Question about General Electric DWXR483GGW Gas Dryer
BOILER WILLNOT IGNITE - General Electric DWXR483GGW Gas Dryer
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
When I look up this model it is and electric dryer check breaker the dryer will not heat on 110 volts so if one side of the breaker is tripped it will not heat but will run
Posted on Nov 23, 2013
I have a honeywell S8600f ignition control on my Crown Boiler after ignition it will run for three to four minutes and then start to short cycle
Sounds like the flame sensor may not sending a signal back to the controller. clean the sensor with a non abrasive like scotch bright.
Jan 10, 2015 | Heating & Cooling
Funace willnot stay lit
Sounds like you may have a dirty flame sensor. Try cleaning it with steel wool or Emory cloth.
Mar 16, 2014 | Amana GMH950453BX Gas Furnace
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Boiler without flame sensor
Sounds like the hot surface igniter is also a local sensor. If you unplug the molex 2 wire plug of the igniter, and turn your meter to resistance, I found that it should read under 110 Ohms. If it is over that amount, the igniter may not sense the flame. Replace the hot surface igniter.
Dec 03, 2013 | Bryant Heating & Cooling
Peerless Boiler - Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will
Did you bleed the air out of the pump. The boiler has a flow switch that has to make before it will let the boiler lite. Make sure you have all of the air out of the system and are pumping or flowing water and not air...Also check to see if you didn't happen to of tripped the limit it has a manual reset. Red Button on the front of limit.
Nov 13, 2013 | Heating & Cooling
Boiler lights and runs Ok when first switched on, when it goes to reignite, it just keeps clicking (sparking) Pilot lights but boiler will not fire up.
This isn't very helpful at present.
What's the make and model of boiler?
Do you mean after the first (successful) ignition subsequent ignition attempts fail?
What happens if you turn the electrical power to the boiler OFF, then back ON ?
Feb 07, 2013 | Baby Gear
Boiler won't light you here fan kick in then light comes up red on b can anyone help please?
First try to ignite the pilot light yourself. Instructions for igniting your boiler can be found in your boiler's manual or sometimes in the inside door of the boiler. If your boiler's pilot light won't ignite, you either have a gas supply problem or you'll need to call in a Gas Safe Register approved engineer for a repair.for details click
Nov 24, 2012 | Heating & Cooling
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
General Electric DWXR483GGW Gas Dryer Logo
41 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
