Question about Funai Sylvania 19" Class 720p 60hz LCD HDTV - Black LC190SS2
LC190ss2 will not turn on
I use this television very rarely and I have tried moving it to another location in the house and with the remote and the button on the tv and it will not turn on. Any advise or is it just dead?
    Top Expert:
  • Funai Master
  • 34,153 Answers
Could be power supply failure.
Posted on Nov 23, 2013
What is the code for sylvania LC190SS2
0101 0107 0110 0152 0166. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 30, 2014 | Sylvania Televison & Video
How do you activate sylvania television model LC190SS2 closed captioning
Press the button marked "CC' on its remote control once. Press once will activate the captioning, and an other press will deactivate it. It is toggle type.
Electro help
Jul 23, 2014 | Televison & Video
Sylvania lc190ss2 remote codes free
Setup codes to check with Sylvania brand TVs are: 1274 1007 11571052 1046 13471049 1091. If you wish to get more, check the sites liked here.http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option.
Jul 15, 2013 | Televison & Video
Remote Model UC7087T will not come on from the remote will turn on at wall switch. will not work in reverse motion
I have the same problem. I kept turning the wall switch on and off quickly and slowly until i could hear the relay in the fan housing click. When this was done the fan switched into reverse but i still cannot control it properly from the remote. I have had this fan for about 3 yrs. Also you can check the "Dip" switch settings in the remote ( remove the battery cover they are located behind the batteries, you can move them with a pen) and inside the fan housing, Make sure they are set exactly the same. I think vibration may make them move in the fan part. Make sure they are fully set in the same position.
Apr 19, 2011 | Universal Remote Control Hampton Bay...
Moved to a new house, set up tv.........no sound. volume control moves but no mute to be found. no remote either.
Check the speaker either its disconnected to connector.try to open the cover of ur tv and check the connection of the wire to speaker.
Apr 04, 2011 | Pioneer PDP-6071HD 60 in. Plasma...
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
Pip box will not turn off moves all around screen with button but wont turn off lost remote
Turn the set off and then unplug it for about 30 minutes. If that doesn't work then you will have to locate the original remote.
Remotes.com
Nov 18, 2009 | Hitachi Televison & Video
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
Funai Sylvania 19" Class 720p 60hz LCD HDTV - Black LC190SS2 Logo
54 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
