Question about Huawei Cell Phones
HI I HV A HUWAEI M931 AND IT WAS WORKING PERFECT AND ALL OF SUDDEN IT DOESNT POWER ON AND I JUST GET A FLASHING RED...
MODEL M931 IT WAS WORKING PERFECT AND SUDDENLY DOESNT POWER ON; I PRESS D POWER BUTTON AND ALL I GET IS ARED BLINKING LIGHT (BLINKS 3 TIMES) AND DOESNT POWER ON
    New Friend:
Make sure the battery is full charger or remove it and use the power cable only .if the power work the problem is the battery. Press the power button 3 time then hold it until il power off. Turn back on. Open it and make sure the conection from the LCD is right pug it to the main circuit look for standby and weikup key combination on the manual.
Posted on Nov 23, 2013
4 Suggested Answers
SOURCE: my nokia 3110c mobile got switched off suddenly and its not switc
did the phone fall in water, on the flow or do you download from the net?.
If it fell on the flow that might cause it to be blinking the way those due to the force it use to land on the flow.Also if it fell in water, water can damage the phone automatically cause water is not friendly with chips in phones.
When downing from the net, some of those application are virus infected, you might have downloaded a virus with an application with what your trying to download and might affect your phone causing it to blink and go off.
So you need to flash the phone to restore the memory back so that it can come on normally again.
Take care.
Posted on Mar 15, 2010
nabulaila975
  • 205 Answers
SOURCE: mobile is not starting, light is just blinking.
try to download new software
Posted on Apr 18, 2010
SOURCE: I hv a blackberry 9000 phone and the red light
hi,
blackberry 9000 service light flashing phone no on
not charging
no pc concet
pls help me as soon as possible
Posted on Jul 01, 2010
Sony 60
Have you check the sleep timer? It could be possible reason why your tv shut off every 30mins. bc the timer was set.
Feb 20, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Huawei user guide
ahh,,ok think you
Nov 23, 2013 | Computers & Internet
Unlock code for huawei
Hi,what is the specific model of your Huwaei phone? You can unlock your Huwaei phone safer and easier using unlock code. You can get the unlock code from www.classicunlocking.com at affordable cost with easy unlocking instructions.
Sep 15, 2012 | Cell Phones
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Rca D61W20 52 in power supply
If the deflection power board was changed with a known good one . then the HV splitter block would be suspect then followed by a bad CRT next. I would try removing one CRT drive board at a time by letting it hang free wires attached then trying to power up the set if it doesnt power up then try one of the other crt drive boards after reattaching the one you previously unhooked. If the set powers up if any certain CRT board is removed you will know the problem is that CRT. If it doesnt power up then its most likely the HV splitter. You can get replacement CRTs, boards and HV splitters that have warranties from www.tvrepairworld.com
Jan 22, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cell Phones Logo
107 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
rostit
honeybun1986
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
