Question about GE Washing Machines
Pillow exploded in washer - feathers everywhere! I got out as many as I could, then just ran the washer thru a cycle, now it won't complete a cycle and it sounds like the motor is stuck
    Top Expert:
  • GE Master
  • 41,919 Answers
More likely, the pump or drain line got clogged.
Posted on Nov 23, 2013
5 Suggested Answers
SOURCE: washing machine clogged with feathers
The pump is plugged most of the time it is under the washer take the hoses off and clean it out. Make sure to try to get ant feathers out of the hoses also
Posted on Sep 05, 2012
livewire874
  • 618 Answers
SOURCE: Duck Feather Pillow In Washer.
Pull off the lower front panel and reach up on the right of the washer to the door lock assembly you will feel a tab hanging down pull it and the door will release. Clean out the drain filter and pump hoses etc. Rise it out and you may have to clean the filter a few times.
Posted on Nov 29, 2010
SOURCE: samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Posted on Mar 08, 2009
  • 4088 Answers
SOURCE: Water Everywhere
Look for loose, cracked, pinched, broken hoses to and from the water pump or leaks from the water pump itself. The outer drum could have a rust-through that leaks. This can be repaired with epoxy, but the inner drum must be removed to access it. The cabinet top is opened by using a putty knife or similar tool to push straight back under each front corner which releases a spring latch. Sometimes, the drain hose outlet is pushed from the house drain by high water flow. Tie the hose to the drain with tape or cord. Fill the tub with water, then stop the cycle and watch for leaks.
Posted on Aug 07, 2009
Washing machine clogged with feathers
Sep 05, 2012 | Washing Machines
Duck Feather Pillow In Washer. Feathers everywhere. door will not unlock or drain water. help
Nov 29, 2010 | Maytag MAH8700A Front Load Washer
Kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Oct 01, 2009 | Kenmore 46462 Front Load Washer
I need to remove the drum to clean the inside part of it
go in touch with BOSCH customer service and tell them ur problem....i don't think u have to remove the drum to fix ur problem.....so find out yourself from bosch......good luck
Mar 12, 2009 | Bosch Exxcel WFO 2864 Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
I washed a feather pillow and it busted, now it wont pump water out.
There is a filter down in the bottom front of the washer (below the drum) that is probably clogged with feathers. It is a pain to get to, but once you get it cleaned out, the washer should spin and drain without problems.
Oct 25, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
262 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
