Question about Roberts 10-22500 QEP 7 Tile Wet Saw
Switch won't work
This saw has been a real workhorse, I use it for cutting 3/8" bars from marble, granite, onyx, travertine and flagstone. Never had any problems, always wash it after each use, dry thoroughly. The other day I set up ready for cutting and hit the switch, checked power source all the same except it did not start? It is the QEP no. 22500 7" wet saw, 4.8 amp
  • 3 Answers
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Posted on Nov 23, 2013
Testimonial: "Not so sure about messing with circuit, broken wire? I can just order that switch and replace without actually repairing the wire. The broken wire is within the switch? I've done some electrical work ie replacing ceiling fan switches, lamp cord switches, and outlets in walls. Is this a can do for a non electrician!!!"
What are modular kitchens?
Modular Kitchen a term used for the modern kitchen layout, which consists of number of cabinets to hold different things in different sections. There are two sections namely floor section and wall section, floor section is one having cabinets attached to the floor and wall section having cabinets attached to the wall and basically near to the rooftop
Types of Modular Kitchens
U shaped
L shaped
Straight
Parallel or Galley
Island Layout
You can find various types of affordable modular kitchens manufacturers
here https://www.exportersindia.com/indian-suppliers/modular-kitchens.htm
Feb 01, 2016 | Relton 3/16" x 6" long Groo-V Tip Granite,...
Where can I buy high-quality bathroom tiles in London?
There are a lot of tiles and marbles suppliers and manufacturing companies in London who provide an exquisite range of top-quality porcelain and ceramic tiles suitable for both indoor and outdoor spaces including kitchens and Ceramic Tiles Bathroom in London.
MKW Surfaces offers one of the biggest ranges of bathroom tiles in the UK at very reasonable prices. In ancient time, fine stone that adds a touch of luxury to any space. It comes in hundreds of different colors and patterns and every piece is unique. Explore at: Carrara Calacatta Natural White Marble Kitchen Worktops
Jan 19, 2016 | Felker FRS-38 Tile, Marble & Granite Rail...
Water pump outlet is not getting power for the pump. Could it be in the on/off switch or something tucked in the support arm. Thanks
probably fried the pump. If you replace the pump go to a hardward store and get a pump there..lots cheaper than willcall at ur tile dist center. Or the hoses are clogged if you do a lot of Travertine and stone cutting. One more possibility is where it plugs in on the saw may have shorted out.
Aug 25, 2015 | Saws
Why does tile veer off?
If you have a bridge saw. The blade and motor may not be parallel with the rails the motor travels on.
Feb 18, 2014 | Felker FRS-38 Tile, Marble & Granite Rail...
Clean oven burner
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 23, 2010 | Kenmore 79013 Stainless Steel Gas Kitchen...
I want to change from a white door panel to a stainless steel front on dishwasher. kenmore model 3 16374300 . Where do I order the front.?
Warner's Stellian in Saint Paul can help for exchange. For cleaning stainless steel we reccommend DeBruce Polish. The "green cleaner" DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more.
Dec 13, 2009 | Kenmore 24 in. 15173 Stainless Steel...
MK-275 (marble) with Travertine?
Any blade for marble will work well for travertine also.
Oct 04, 2009 | Saws
Grainite floor has chipped
the best filler is epoxy,your best bet is to go to a marble and granite fabricating company,they will sell you the resin and they will tint it the right color, so all you have to do is add the hardener and fill where needed,they would probably charge you 5 to 10 dollars,this would save you from buying the epoxy resin,hardener,and the green tint, most of these shops that install granite have people there that will tell you how to apply it to your tiles.good luck
Jul 12, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Small chip in granite countertop
Well you should seal your granite counter at least once every two years because granite is pourus. Theres something called Granite Guard you can use to seal your counters and other different sealers as well. You can pick some up at your local home and garden supply store.
Apr 02, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Roberts 10-22500 QEP 7 Tile Wet Saw Logo
158 people viewed this question
Top Roberts Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Roberts Saw Expert? Answer questions, earn points and help others
