Question about GE RM24948 Remote Control
GE RM24948 Code input prob
When i had the book for this remote i remember inputing a four digit number using the volume + and - and the channel + and -. Now i cannot remember where to start and in which order they should be pushed. All the manuals online say to use the rewind play and fastforward buttons but i don't remember doing that last time. HELP HELP HELP
  • 42pete Feb 09, 2008
    trying input codes for awia dvd player manuel says 0414 ? cant get it rt help
1. Ch (-) x #
2. Vol (-) x #
3. Ch (+) x #
4. Vol (+) x #
Hope that helps. Same thing happened with me and it took a while to figure it out. like 20 min. to try all combinations with all different codes.
Posted on Nov 27, 2007
Can a symphonic TV model WF203 be put in video mode without a remote
Only if you have a source button on the tv itself. On many of the newer sets you have to have the remote to access your other inputs. Without the remote, nada. And forget universal remotes - they only provide for the most basic functions and video source is not one of them. And you get hosed on original remotes.
Sep 25, 2015 | Symphonic Televison & Video
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
I need the code for ge universal remote rc24993-c to connect to a sony television please
Universal remote allow you to control multiple electronic devices with a single remote. You can use the remote to work your TV,DVD player, cable boxes and other devices from the comfort of couch.Philips is a popular manufacturer of universal remotes.to program a GE remote for SONY TV,you will either need to input the device code or perform a code search
direct entry
first.turn on your TV manually. next.press down and hold set-up on the remote.the red indicator light will stay lit.after that.press the TV device button to let the remote know you wish to program a television then.enter your device four digit codes on the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the number zero in the beginning of the codes finally.test the remote to ensure it works.with the turned on,press the channel button and see if the TV responds..if it is work the remote programmed and you are done,if it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
Mar 09, 2011 | Televison & Video
I have a GE Universal Remote RC 94948-H 1030. It only has channel and volume buttons how do I program it. I know the code but not the method of input. Its something to do with the channel and volume...
I have a GE Universal Remote RC 94948-H 1030. It only has channel and volume buttons how do I program it. I know the code but not the method of input. Its something to do with the channel and volume buttons
Feb 04, 2011 | Televison & Video
How do I bypass Mitsubishi VS-4502R security code?
Don't know that you can do it with universal remote. to release channel lock on previously locked channels or inputs, 1 press the menu button 2 press 5 3 press 2 (4) the display then askes for I.D> number (5) press 9 and quick view at the same time, this turns channel lock feature off.
Sep 05, 2009 | Televison & Video
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Need code
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Apr 16, 2009 | GE RM24948 Remote Control
Need code
I called one-for-all and got a repair number and then sent the remote to them to have the codes added.
Dec 13, 2007 | One For All URC4220 Remote Control
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
GE RM24948 Remote Control Logo
290 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
