Question about Vivitar ViviCam 6324 Digital Camera
Memory card error message - Vivitar ViviCam 6324 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
What type and size memory card are you using? The 6324 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Posted on Nov 23, 2013
Memory card error on fujifilm finepix series s4800
Eject the bad memory card and try another one. It is possible that the card in the camera right now has corrupted. You can try some of the online recovery tools to try and rescuse what is on the card if you have not already transfered the pictures off the camera.
Dec 10, 2014 | FUJIFILM Cameras
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
How to remove card error in fujifilm jz300 camera
Welcome to FixYa.
The reasons why do you get a message "CARD ERROR" are:
1. The memory card is not formatted.
2. The memory card requires cleaning or memory card is damaged
3. Incompatible memory card.
4. Camera malfunction.
What do you need to do are:
1. Format the memory card.
2. Clean the contacts with soft and dry cloth. If the message is repeated, format the memory card again. If the message persists, replace the memory card.
3. Use compatible memory card.
4. Contact FujiFilm dealer.
Feel free to send us your comments and suggestion fi this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | FUJIFILM FinePix JZ300 Digital Camera
Printer error 70
Brother DCP-165C inkjet All-in-One Printer Error Messages
Once you are familiar with the types of errors that can occur while you are using PhotoCapture Center, you can easily identify and troubleshoot any problems.brother-dcp-165c.jpg
Hub is Unusable.
This message will appear if a Hub or USB Flash memory drive with a Hub has been put into the USB direct interface.
Media Error
This message will appear if you put in a memory card that is either bad or not
formatted, or when there is a problem with the media drive. To clear this error, take out the memory card.
No File
This message will appear if you try to access a memory card or USB Flash memory drive in the drive (slot) that does not contain a .JPG file.
Out of Memory
This message will appear if you are working with images that are too large for the machine's memory.
This message will also appear when a memory card or USB Flash memory drive you are using does not have enough available space to scan the documents.
Media is Full.
This message will appear if you are trying to save more than 999 files in a memory card or USB Flash memory drive.
Unusable Device
This message will appear if a USB device or USB Flash memory drive that is not supported has been connected to the USB direct interface (For more information, visit us at http://solutions.brother.com.). This
message can also appear if you connect a broken device to the USB direct interface
Nov 03, 2010 | Brother DCP 165C Compact Color Inkjet...
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
Feb 17, 2010 | Pentax Optio S5i Digital Camera
How to copy message from memory card to phone memory in nokia n72
open the folder, mark the messages, set destionation as phone memory, then copy them
Jan 06, 2010 | Nokia N72 Cellular Phone
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
"OUT OF MEMORY" Error Message
Have you used formatted cards? It may be that due to the incorrect memory card - the camera defualt memory has changed to the camera - Can you check the settings?
May 11, 2009 | Nikon COOLPIX 5100 Digital Camera
Vivitar ViviCam 6324 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
