Question about Fujitsu Office Equipment & Supplies
Fi-6240 error H0 - Fujitsu Office Equipment & Supplies
    Problem Solver:
  • 16 Answers
Motor fuse alarm. looks like you need a new main board.
Posted on Nov 26, 2013
Jvc vcr/dvd recoroder dr-mvis
No power, No Display - test voltages on secondary side of transformer were pulsating
Check diodes 6230, 6240, 6210. They are BYW98 Rectifiers, in my case it was s/c. Thanks to Sparky for similar tip - Philips CD Model: CDR770/00
No power and no output
Replace C6 with 4.7uF, 250v
No power, voltages on secondary side of chopper were very low and pulsating
Check diode 6230. It's a BYW98, in my case it was s/c. Note: it's the rectifier for the 14v line
Dead, no power up on pin 2 of ic601
Replace x601 on main processor ic601
(Brko) Toshiba DVD Model: SD-1750 / SD-2800
No sound
Replaced C927 / C928
Nov 26, 2007 | Audio Players & Recorders
I receive an error F4 on my scanner when I turn it on. Will not scan. Any suggestions?
Hello Larry,
The F-4 error in Fujitsu fi-6240 scanner indicates Background change over unit malfunction alarm. It may be caused by the malfunction of background motor or optical unit or damaged optical cable.
You are recommended to contact the nearest Fujitsu scanner service center for rectification.
Thanks & regards,
ScanCare
Sep 25, 2013 | Fujitsu Fi-6240 Flatbed Scanner
Fujitsu Fi-6670. I have a little (microscopic) piece of paper stuck under the lower screen, so when scanning it appears a blu line over the whole page. How can i get it out? Thanks
Hello Alex,
You need to open the scanner and de-assemble some parts to remove the piece of paper which involves technical expertise. I would recommend to contact a Fujitsu scanner technician or call your nearest service center for assistance.
Thanks & regards,
ScanCare
Aug 28, 2013 | Fujitsu Fi-6240 Flatbed Scanner
Sense key=0x4,asc=0x48,ddes=0x88
Hello Adil,
Does your scanner display H0/H8 alarm?
Does the same symptom occur after turning OFF and ON the scanner?
Does any foreign object get inside the Control PCA? Check the control PCA.
Are the cables between Control PCA and the motor damaged? Or are the
connectors connected correctly? Check throughly.
If the issue is not resolved, then you may have to replace the Control PCA as the motor fuse is located in the control PCA unit. For replacement you are recommended to contact Fujitsu scanner expert.
Thanks,
ScanCare
Jan 22, 2012 | Fujitsu fi-6130 Flatbed Scanner
I want to drivers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
auiioo3
Apr 15, 2009 | A-Trend ATC 6240 (ATC-6240) Motherboard
Need to no how to find Type 1 error for statistics on TI 83 plus
Carry out the test. The calculator will display a p= value (or if you draw it - it will be the shaded area). This is the type one error. Why? Well if H0 is true then your t-test will come from this distribution. Think of the bell shape as a histogram - you have one value you are comparing to it. Is this value typical of this "histogram"? If the value is near the centre of the bell it is reasonable that it came from it. If it is in the extreme it probably didn't and so we reject H0. The type one error is the probability that we reject H0 given that it is true. H0 assumes the t value comes from this distribution - so it is the probability of getting this value or something more extreme. (i.e. the shaded area. Incidently this is the same way of finding the type one error for any test.
Jan 08, 2009 | Texas Instruments TI-83+ Graphing...
Open Questions:
91 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
