Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fault no. 37 - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • Fisher and P... Expert
  • 554 Answers
37. (00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3
minutes. There are three likely reasons for this fault. One is that the drain hose or the
pressure switch hose has been squashed or kinked and the pump out rate has been
dramatically reduced. The second possibility is that the pump is partially or fully blocked.
The third is that the pump is not operating due to Motor Control Module, wiring or pump
failure. This fault could also appear if the machine is pumping to an unusually high head of
drain hose or into an extended length of drain hose. The fourth possibility is a diverter
valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation
mode, giving the module the appearance the pump is not lowering the water level.
Primary Source: Pump System.
Action: 1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 1-metre extension hose of the same diameter
fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain
hose is not blocked.
5) If the bowl contains water, then service the pump from the top of
the machine by removing the top deck and inner bowl. Bail out the
water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action: 1) Check the pump harness is connected correctly to the pump.
2) Check continuity of the pump harness.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
pump is rotating. If it is not operating, and Primary and Secondary
checks have been performed, then replace the Motor Control Module.
Posted on Dec 13, 2013
Fault code 37
If you wish to get some details about washing machine service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 27, 2016 | Fisher Washing Machines
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Fault code 37
Hi just read your posting.I need to know the brand and model number of your machine.Looking forward to your reply.
Nov 29, 2012 | Washing Machines
Fault code 37 Yamaha V-Star 1300
Hi, Kenneth for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ERROR code 37
Yamaha Fault Codes
http://vstar1300.pbworks.com/w/file/fetch/94628933/1300VStarServiceManual.pdf
OEM parts for Yamaha
Yamaha 2007 XVS1300AW Owner Manual
Jun 15, 2012 | 2009 Yamaha V Star 1300
Fault code 37
fault code 37. washing machine will not empty bowl.
Feb 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
2 yr old Panasonic Viera 37 in - has very narrow
This is a fault developing within the screen, the only remedy is to have the screen replaced, there is no exact answer to why this has happened, it is just the nature of a plasma screens make-up that sometimes a fault can develop like this within the characteristics the display
Nov 16, 2009 | Panasonic TH37PX60 37 in. Plasma...
Fisher&paykle washing machine, intuitive eco. fault 37
hi
fault 37 is usually associated with the pump not pumping out all the water in time
cheers grant
Oct 21, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
