Common problems flat screen tvs
Hello I have a 42 inch Sylvania tv model # LC42oSS8 that can take up to 15 minutes for an image to display after powering up. The picture quality is great and no other issues. any advice on what part to change? Many thanks Rob
  • rzarra Nov 25, 2013
    Hi Chas thanks for responding to my question but the issue with my tv is internal of the tv it self. The input is correct and my other tv works well on this set top box. Can you recomend any parts to change internally or the tv. Thanks
    New Friend:
  • 30 Answers
Make sure you are on the right input, make sure video signal is up and running, So if you are pumping a MAC TV or PS3 into it make sure they are up and running and input on TV is set to HDMI or DVI-I or what you need. On newer TV's some have a sensing feature that searches for a correct input and the HZ you have it set for. If you are in the USA 59-60hz will do it. Europe uses 50hz. Just check with only one device hooked up and go from there. 15 Minutes is way too long.
Posted on Nov 23, 2013
  • 4102 Answers
SOURCE: 42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Posted on Dec 14, 2007
SOURCE: lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Posted on Dec 29, 2007
  • 58 Answers
SOURCE: invalid format
the comp is set to an unsupported screen res. set it to 640x480 and try again.
Posted on Dec 06, 2008
MNfisherman
  • 11896 Answers
SOURCE: sylvania 42" flat screen won't turn on
First you should check the fuse and the wiring in your tv by removing the back cover. Make sure no wires are bare or touching. If there are any, wrap them with electrical tape.
If you cannot see anything wrong by looking, then it is probably the set has a bad transformer (high voltage)
Posted on Jan 17, 2009
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
My 37 inch Sylvania TV model LC37SS9 M turned off by itself and to turn back on. I was watching dish network at the time
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 01, 2015 | Sylvania Televison & Video
My 42 inch sylvania hdtv screen is broken and not showing a picture
If the display panel (PLASMA DISPLAY PANEL--PDP) is damaged or broken etc it is fatal as the cost of the part alone will exceed the cost of a new set.
Oct 15, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
Trying to put on closed caption on gateway tv 42 inch-a large black screen appears
don't know if CC can be used when watching a DVD. seems to me that it would cause a conflict on the display where the dvd is sending the image which is really not part of the TVs input control options.
CC is usually related to the digital signal from signal broadcasts and not video images coming from an external source. if it was controlled i would think it would be from the dvd remote controller. not the tv.
Oct 14, 2012 | Gateway FMC-901 w/ 42-inch Plasma TV...
Where do i plug my cable cord into on my 42 inch sylavania
Hello - The fact is that your TV, as a HDTV ready device, is really a display monitor that does not contain any TV tuner. There is no place to attach your coax TV connector.
To view TV on the unit you would have to either subscribe to cable or satellite TV service or buy yourself an external TV tuner such as listed HERE (I'm not recommending this tuner just showing the kind of device you would need.)
Regards and thank you for using Fix Ya.
Mikeywaf
Mar 22, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Help our sylvania 6842thg plasma display tv turns itself off after about 10-15 minutes?
This is a common problem on Sylvania Flat Screen TVs (I have seen a lot of TV with this same problem), It is usually caused by a failure on the Power Board.
A new power board will cost about $150 - $190 USD. If you have experience on electronics repair and want to fix it by yourself, you can get the board through ebay or any online store.
A TV technician may charge about $280 - $ 400 to fix this issue (includin parts).
Read the user manual for warranty information. If the TV still under warranty, contact the manufacturer for assistance on repairs.
Nov 27, 2009 | Sylvania Televison & Video
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
I have a 42"flat screen sylvania turnit on and 3 or 4 seconds it turns back off
Right now the TV is in " Protection Mode ".
Try leaving the TV unplugged for 30 minutes, that way the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a backlight Inverter Board.
Mine had the same problem, it had one bad inverter transformer on the backlight inverter board. Maybe something you want to look at for your TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 06, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Plasma Vizio 42 inch
The main board of your TV is bad. I have seen a lot of TVs have the same problem.
May 31, 2008 | Vizio 42 in. LCD TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
