Question about SkyGolf SkyCaddie SG4 GPS Receiver
Skycaddie SGX is not recognized by USB port
"Driver pre-installation has failed with error #1630()"
4 Suggested Answers
SOURCE: My new Skycaddie sgx had a install problem and now
just wodering if you got the problem sorted. i have similar issue
Posted on Jul 17, 2010
drifterK
  • 4924 Answers
SOURCE: sgx skycaddie will not shut
perform a soft reset(a forced restart basically ) . hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset.(remember that this will delete any information already installed..) push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
Posted on Sep 03, 2010
  • 1417 Answers
SOURCE: i have just bought a
Hello.
If you have the update installed, your Sky Caddie Legend willdisplay the information on startup. You can also change the owner information.You may want to change the information if you purchased the GPS used, ornoticed an error in the information.TOLLS NEEDED AND INSTRUCTIONS ARE STATEDBELOW.Software update 2.42 or higher1 Press the "Thumb Stick" to display the Sky Caddiemain menu.2 Scroll down with the thumb stick and select"Options." Tap the thumb stick to enter the menu.3 Select "Owner Information," and tap thethumb stick to enter the folder.4 Enter or change the current owner data (Name,telephone, etc.). Scroll down with the thumb stick and select "OK."Thanks.
Posted on Sep 30, 2011
I have a SGX and have lost the antenna cover. Can I find a replacement?
Stay AWAY from the SGX. The quality control is really poor. I know of three other users having the same problem, the antenna cover falls off and the unit does not get satelite reception. It becomes a piece of junk. Once that unit got replaced, in less than 5 months, the rubber covering the knob that allows you to select items had a tear and now the unit is no longer waterproof. This is not covered under warranty and they want you to pay $89.95 for a replacement. I am done with SkyCaddie. I have just purchased the new Garmin G6, awesome device, no annual fees, long battery life and touch screen enabled.
Look at the following link to get other user experiences.
Amazon com Customer Reviews SkyCaddie SGX Golf GPS
Feb 09, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
On starting skycaddy sgx, I get the following message on screen: application servicesd.exe encountered a serious error and must shut down
Find the maual or go to ther website. see if they have a software fix for it if not you are most likely going to have to reinstall the software. Errors like these are startup errors and there is no work around that i know of.
Nov 04, 2013 | SkyGolf SkyCaddie SGX GPS Receiver
I have just bought a secondhand skycaddie SGX how do i re-register it in my name?
Hello.
Sep 22, 2011 | SkyGolf SkyCaddie SGX GPS Receiver
SG4 Sky Caddy driver
Make sure your cord is plugged into the SkyCaddie with the cord pointing down towards the battery, not going up. It makes sense and it is easier to plug in with the cord going up, but you will eliminate this error if you plug in the cord with the cord going up.
Apr 02, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Cannot get direct connect to work
please check your power y cable cord the comes with the sg3/4 units. they have teeth or tabs on it near the screw and they tend to break if it slips while the person is trying to screw it in. that will cause the unit to not connect no more and they will need to replace it, but please don't use a broken power y cable, it will cause it to slide around and shorten it out. most of the time this occurs after the person had it for awhile or they screw it in too tight and over time that will strip it out and cause it to no longer to screw in...
Jan 06, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
SkyGolf SkyCaddie SG4 GPS Receiver Logo
102 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
