Printer adapter from serial 25 to usb printer
I need connect output from doorKing remote control receiver mod 8054 out to printer 25 pin to a usb input printer
    Champion:
  • 221 Answers
Frequently the 25pin plug on a PC is a parallel port, not a serial port. Perhaps it is this you mean.
Posted on Dec 16, 2013
Kids gave me a printer/scanner Epson model number c171a. Need the cable to it. AN oldie but looks like a pretty nice printer. Can you help??
The cable you need depends on the unit. I am not aware of a C171a model from Epson. I have seen it listed as a version of the RX500. In that case you need a USB cable with A/B male ends.
Otherwise, most printers (from about 1997 on) will use a USB cable. This has two male ends - a square end goes into the printer and a rectangular end that goes to the computer (called A/B). For older printers (there may be multiple ports or just one), you may see a parallel port (the cable has a wide rectangular plug on both sides with 36 pins) or serial port (the cable may have DB9 (9 pin), DB25 (25 pin) or both). Often it is called a RS-232 port. For a parallel port connection, you would need one that is designed for scanners and bi-directional communication (USB to parallel adapters are available to connect this to a new computer but you still need the bi-directional version). Similarly, USB to serial adapters are available.
Generally you can tell what cable you need by looking at the back of the unit where the ports are. (Although some all-in ones have the USB cables in other places - routed through the side of the unit but the plug is near where the ink cartridges go.) Then the size and pin counts for parallel or serial tell you what cable to get. There is usually a symbol indicating the cable type as well near each port. USB cables are usually indicated by a tree like symbol with curved branches.
I hope this helps.
Jul 25, 2010 | Epson Office Equipment & Supplies
To connect gps to computer wich pins do i connect of nmea cable?
pins 2(-) and 5(+) on a 9 pin serial cable, then you need a usb to serial adapter for input into the computer if you do not have a built in 9 pin serial port on you computer because the usb moves the information faster than the gps signal. gps is roughly 4800 baud, usb is moving so much faster you need a buffer
May 19, 2010 | Furuno GP32 GPS Receiver
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Large data transfer laptops, cable, or USB adapters DELL Lat-C
the system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Nov 23, 2008 | HP Pavilion dv9000z Notebook
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Epson TM-U325D Serial Printer - No Print Activity
make sure you have the printer added in the printers window of the control panel. Epson Expert
suggests adding the printer as "generic". Mine is USB, so I have to run their COMUSB program.
Right now I am having a problem printing receipts. It seems the text is too wide for the line.
Jul 30, 2008 | Epson TM U325D Matrix Printer
Connect to usb on laptop
The Easy affordable solution:
www.sewelldirect.com or (801)356-3823
* USB to Parallel Adapter, part # SW-1302 ($14.95) + * Centronics to Mini Centronics, Part # SW-2104 ($12.95).
I ordered before 2pm EST and received two days later.
Plug usb into computer, wait, then plug in printer. Voila! Instantly worked!!
PS: Found this site after www.monoprice.com Product ID: 2277 (parallel to USB) and ID 257 (male to mini) - $15
Oct 24, 2007 | HP LaserJet 1100 Printer
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
