Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Whirpool side by side - Trying to replace water filter. I cannot turn it to the right to lock it in place. I have tried a pliers several times but it won't budge. Any ideas
    Problem Solver:
  • 20 Answers
Make sure it's aligned right and push it up into place then turn it.
Posted on Nov 23, 2013
Trying to replace the water filter on my fridge/freezer put it in vertical and tried to turn to the horizontal position to lock in place wont turn and don't want to use excessive force any advise plz
Amanda,
I have had to use pliers before in putting those in. Just be careful that you try not to force beyond the horizontal. Also, try pushing in while turning, sometimes that helps.
Jun 06, 2015 | Refrigerators
Water filter on kitchenaid superba not snapping into place
The entire filter with cap attachment must be in place or the water will not be filtered.
Feb 27, 2014 | KitchenAid Superba Architect KSCS25INSS...
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 26, 2011 | GE Refrigerators
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
Whirpool Fridge Freezer water filter replacement problem
sometimes they are very hard to turn use pliers if ya have to counterclock wise
Feb 14, 2010 | Whirlpool Freezers
Water filter light not re-setting
Try holding both buttons on either side of the filter lite in until lite goes off . May be the answer . If not off in about 15 seconds , wrong answer .
Aug 09, 2009 | Whirlpool S20DRSS33 Side by Side...
Cannot remove water filter from LG 26 cu ft side-by-side in the d
Here's the only thing that worked for me in getting the water filter out of my LG refrigerator after trying for three weeks, pulling hard by hand, using high-grip gloves, and trying an oil filter wrench. You have to break or lessen the suction created by the water in the filter. Do this by first turning the filter to the Removal position (in my case, a quarter-turn to the left). Then grip the filter tight and rock it back and forth slowly as far toward the back and front of the refrigerator as possible, while keeping a bit of downward pressure on the filter. This lets the two O-Rings "walk" their way down the insert tube. After only a few pushes and pulls - voila! -- it lets go and will drop right out.
Nov 24, 2008 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
WATERLESS SIDE BY SIDE FRIDGE
Your fridge utilizes a "dual coil" electro-mechanical water valve inlet system (the water from the wall is hooked up to it). One coil for the Ice Maker, the other for the chilled water. The chances of both valves failing at the same time are slim to none... and slim just left town. First, verify your filter installation. Remove it completely, 1/4 turn left and pull. Then reinsert it fully and lock it in solidly with a 1/4 turn right. Pull on it hard to make sure it's locked. Second, get a pair of slip joint pliers or a 7/16" open end wrench. Pull the fridge out from the wall and turn the water off. Remove the hose going into the fridge. Hold the hose in a bucket or pan and slowly turn the water on and let it run for a second to verify water. Then reinstall the hose back on the valve assy. Now, try your water dispenser. If this doesn't work, we can go deeper. Post back with your findings, please.
Jul 29, 2007 | Hotpoint HSS25GFP Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
