Question about Ricoh Office Equipment & Supplies
Does anyone know where i can get parts for a richo aficio mp 2500 printer richo won't sell me any
I need the yellow RJ-45 Connector with pigtail and plug located in the drive unit that mates with the male RJ-45 connector located on the yellow photoconductor drum; Richo will not sell me the part thank you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Here u go m8
parts for your printer
Posted on Nov 23, 2013
4 Suggested Answers
Regaltime28
  • 3 Answers
SOURCE: NEED TO RESET MAINTENANCE MESSAGE
Turn the printer off. Press and hold the select and return buttons while powering on the printer. Release the buttons when the display shows "Perform Self Test". The printer will continue to boot-up. When ready the display will show the word Config Menu. Then press the menu button untill you see the Reset Maintenance Count option. Then press the select button. The reset command shows on the second line of the menu. Press the select button again to reset. Now press the menu button untill you see the Exit menu and press select. The printer will now automatically reset itself and boot up ready to print.
Posted on Jun 02, 2009
Touch2Heaven
  • 145 Answers
SOURCE: need to reset maintenance count on a richo aficio
• After the technician replaces the fusing unit, the maintenance counter must be reset with engine SP mode 7-804. • 7-804-1: Transfer roller • 7-804-2: Paper feed roller • 7-804-3: Fusing unit).
Posted on Jul 27, 2010
santosj27
  • 263 Answers
SOURCE: I have a richo copier
you can change. You have a door right in front of the equipment. If you open that door you see the toner bottles. You pull the old one and then put the new bottle
Posted on Jan 20, 2011
Testimonial: "Thank you so so so so so much. You have solved my copier drama. Thanks so very much"
Where ih coil at copier richo mp c3500
remove the fuser. See the hole in the black plastic assembly behind the fuser? That is what you are looking for. The thermostat is blown. Put some super glue on your finger. Then touch the thermostat and tug. That black mesh pulling back out will reset it. To permanently fix it you need to replace it. A lot of disassembly but much cheaper than replacing it. So long as you know how to do it and where to get the part. Let me know if you need a part number. Otherwise, it will cost hundreds for a service tech to do it. They will only replace the assembly, not the thermostat.
Oct 01, 2014 | Ricoh Aficio Mpc 3500 Color Copier
Please help. My printer is Aficio Rico and the number is MP 2500. It indicates it is offline.
Check the connection to the printer. Check the ports on the driver to see if it's using the IP port or USB. Otherwise the IP's on the network changed.
Jun 22, 2014 | Ricoh Aficio Office Equipment & Supplies
Building custom parallell adapter from j45 to b25 need colr code
If you mean DB25 connector you can try this:
RJ 45 Pin 1 to 5 Volt power
RJ 45 Pin 2 n/c
RJ 45 Pin 3 Gnd (DB Pins 18 -25)
RJ 45 Pin 4 n/c
RJ 45 Pin 5 to DB Pin 1
RJ 45 Pin 6 n/c
RJ 45 Pin 7 DB Pin 14
RJ 45 Pin 8 DB Pin 2
More info about DB-25 connector can be found here.
Jan 07, 2012 | Epson TM Office Equipment & Supplies
How to remove user name and password richo mp 4500
go to sp mode by pressing reset 107 then press stop for a few seconds then inter copier sp then inter mode then search for clear user .......then press it then press execute then tern the machine off the on i hope that well help u
Nov 03, 2011 | Ricoh Aficio 450 Copier
I have a richo copier aficio mp c2050 the toner bottle is full and i need to change it, however i cannot find in any books where the bottle is and how to change it. does anyone know where it is on this...
Jan 20, 2011 | Ricoh Aficio 450 Copier
I just purchased a Richo Aficio 1600 and have no instructions on how to install the developer. Where is the PCU?
The PCU is the image unit, where it is the fotoconductor drum, in the inferior part it has a flange that releases the image unit to remove it. It is possible to be added by the later part has a cover of plastic right transparency to means.
Nov 06, 2009 | Ricoh Aficio MP 1600 Black and White...
What is the cost of richo aficio mp1600le catridge?
Depends on whether you go compatible, or Oem. Although i use a lot of compatibles for various makes of equipment, Ricoh is very sensitive, and I don't find they work very well, so I would stick with Oem. Bottle is around $45-$50CDN
Feb 18, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Fusing belt
Where in Europe are you? I know of a few dealers and myself works for one but we don't ship outside the UK as the voltages are different.
Please mail back. The other thing we do not sell the belt on it's own we only sell the unit this is how it comes from Richo.
Thanks J
Nov 23, 2007 | Ricoh Aficio AP3800C Laser Printer
49 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
